ᐅ Which screws and wall plugs are most suitable for installing the IKEA Metod kitchen system?
Created on: 16 Mar 2024 08:47
bilgem
bilgem
16 Mar 2024 08:47
Hello everyone, I am currently planning to mount an IKEA Metod kitchen cabinet on the wall and am wondering which screws and wall plugs are best suited for this installation. My wall is made of solid brick, partly with a plastered surface. I want to make sure that the fastening is stable, durable, and well matched to the weight of the Metod units.
I am particularly interested in:
- Which wall plugs do others typically use for this type of installation (space requirements, material compatibility)?
- What kind of screws should I pay attention to (length, diameter, material)?
- Are there any specific combinations that have proven especially reliable with Metod?
I have heard of expansion anchors, cavity anchors, and also metal wall plugs, but I’m not sure which is best for a solid wall. I would appreciate any informed advice, ideally based on professional or practical experience. Thanks in advance!
U
uslis47
16 Mar 2024 09:16
Hello bilgem,
For installing the IKEA Metod kitchen units on a solid brick wall, I indeed recommend using nylon plugs or specialized plastic anchors designed for solid walls. The commonly used expansion anchors work very well here, as they expand inside the drilled hole, providing a secure hold.
Regarding screw selection:
- Screws with a diameter of 5 to 6 mm (0.2 to 0.24 inches) and a length of about 50 to 70 mm (2 to 2.75 inches) are generally suitable.
- Make sure the screws are rust-resistant (stainless steel or galvanized), especially if the kitchen might be exposed to humid conditions.
It is also important to drill the holes accurately to scale—usually using a masonry drill bit of the appropriate size for the anchors.
One more tip: If your wall is a bit uneven, it can help to align the units first and mark the drilling points on the wall before drilling. Good luck!
Palenar
16 Mar 2024 12:29
I would like to add some technical details that are often overlooked when securing IKEA Metod kitchen units:
1. Anchor type: For solid brick walls, I recommend universal anchors or high-performance plastic anchors. These provide strong holding power and maintain their shape well. Metal expansion anchors can also be used but are often oversized.
2. Anchor size: Typically, an 8 mm anchor is recommended, as it offers sufficient grip in the masonry while remaining durable.
3. Screws: Zinc-plated chipboard screws are suitable for the wooden parts of the kitchen units. For wall fastening, it is better to use screws with a metric thread, for example, 6 mm in diameter and at least 80 mm (3 inches) long, to ensure they engage deeply enough in the anchor.
4. Weight and number of fastening points: Average Metod wall cabinets weigh up to 40 kg (88 lbs) per module. I recommend at least three fastening points per cabinet unit to distribute the weight evenly and avoid load peaks.
5. Installation tip: Check for cables and pipes inside the wall before drilling. It is also advisable to use a chalk line and a spirit level tool.
One more question for bilgem: What are the dimensions of the modules you plan to install, and do you intend to integrate heavy dishwashers or other built-in appliances?
bilgem
17 Mar 2024 07:52
Thanks for the tip, Palenar! The wall cabinets are each 80 cm (31.5 inches) wide and 40 cm (15.7 inches) high, a fairly standard design. Built-in appliances like dishwashers or similar will be installed in the base cabinets; the wall cabinets are intended mainly for dishes and glasses. Therefore, I am expecting a maximum load of 25-30 kg (55-66 lbs) per cabinet. The rooms have been partially renovated, so I can rely on fairly stable walls; however, I want to avoid any risk because of the heavy fronts and door hardware. Your detailed recommendation regarding screw size and anchor type is already very helpful.
kasan
17 Mar 2024 11:35
I think it’s important not to oversimplify the choice of anchors. While expansion anchors and universal anchors are often recommended, for older solid brick walls with possible cracking or inconsistent masonry quality, chemical anchors are definitely worth considering.
Chemical anchors have the advantage of transferring loads along the entire length of the anchor and by bonding to the borehole walls. They are also less sensitive to vibrations. Since IKEA Metod units are often subject to dynamic loads (e.g., from opening and closing doors), chemical anchors can hold them more securely.
Of course, using chemical anchors requires more effort (processing time, curing), but if you are looking for a long-term, highly durable solution, I believe they are especially worthwhile for heavy cabinets or older walls.
What do you think?
Joe52
18 Mar 2024 15:03
I would like to share a personal perspective. Having installed several IKEA Metod kitchens myself, I am familiar with the uncertain feeling of choosing the right anchor-screw combination for old walls.
What has worked well for me is using high-quality nylon expansion anchors (at least 8mm (0.3 inches)) together with zinc-plated, sufficiently long screws. It’s important to ensure that the screws engage deeply enough into the anchor, as this is a crucial point that is often underestimated.
Something I especially underestimated as a non-professional is the importance of precise drill depth and diameter to properly install the anchor. I remember that after mounting the units, they were still somewhat wobbly despite using anchors – only after adjusting the holes with the correct drill bit did everything become stable.
So, it’s best to take your time, not rush, and double-check that all holes are drilled correctly and to the right depth.
I hope this helps you with your decision!
