ᐅ Which screws must not be mixed up when assembling the Ikea BESTA unit?
Created on: 10 Aug 2020 09:17
Hugh45
Hugh45
10 Aug 2020 09:17
Hello everyone, I have assembled some furniture from the Ikea Besta series myself and I am not entirely sure which screws or fasteners must definitely not be swapped during assembly. This especially concerns screws with different lengths or diameters, which are not always clearly distinguished in the instructions. My question is specifically: Are there any screws in the BESTA system assembly that must never be used in the wrong places because this would affect the stability and functionality? I want to avoid mistakes that could later cause instability or damage to the furniture. I would appreciate any specific tips or experiences you can share!
Kolepau
10 Aug 2020 10:19
Hugh45 schrieb:
Are there any screws in the BESTA system assembly that must not be used elsewhere because they could affect stability and function?
Yes, definitely! With the BESTA system, you need to pay special attention to the longer connecting screws and the small Minifix fittings, which cannot be simply swapped out. I once installed two hinges with the wrong screws – it was really frustrating because the doors wouldn’t close properly!
Here’s what you should absolutely avoid:
- Never use longer screws on the thinner side panels
- Minifix screws should only be used in their designated drill holes
- Always use the original screws for the hinges, as they have special threads
If you follow the instructions carefully, everything works perfectly. And if you’re unsure, it’s better to double-check! That makes all the difference. You’ve got this!
Rodolfo
10 Aug 2020 11:02
As an additional factual summary:
1. In the IKEA BESTA system, there are mainly two types of screws that must not be confused:
- The cam lock fasteners or Minifix bolts (usually with a special thread and flat head)
- The longer furniture connector screws (typically used for the back panel or connection areas)
2. Using the wrong screws can:
- Reduce the stability of the furniture
- Damage the drilled holes
- Cause malfunction of hinges or doors
3. It is important to separate screws by type and length and use them according to the assembly instructions. The screws are usually clearly marked.
4. For replacement parts, it is recommended to buy the original IKEA screws, as alternatives often do not fit.
Conclusion: The key point is not to confuse the Minifix fittings with hinge screws and to pay attention to the correct screw length on the side panels.
REPITAR
11 Aug 2020 08:45
Additionally, I would like to create a small guide to help avoid mixing up screws during the BESTA assembly.
1. Overview of screw types:
- Minifix dowels: These are short, with a round head, and are used to connect panels through side holes.
- Long screws: These are mostly used for the back panels and for attaching the legs or other large parts.
- Hinge screws: Usually small and specially threaded for mounting door hinges.
2. Common mistakes when mixing up screws:
- Using minifix dowels in larger holes or as a substitute for long screws
- Using long screws in thinner side panels, which can cause splitting
- Using hinge screws in places without special threaded inserts
3. My tip: Lay out all screws on a surface before assembly and sort them by length, shape, and marking. IKEA includes a hole diagram in the instructions, which you should check several times during assembly.
4. Typical resulting issues are loose-fitting parts or doors that don’t close properly.
In summary: minifix dowels and hinge screws must never be confused, and long screws should only be used in the designated, stable side panels.
pauPierce
12 Aug 2020 17:26
I would like to address the issue of screw mix-ups with the IKEA BESTA in detail, as, in my experience, they often lead to incorrect assembly that can only be fixed with time-consuming rework.
First and foremost, it is crucial that you can distinguish the screws by type, diameter, length, and head design.
- Minifix dowels: These are short, have a special thread shape, and serve as cam connectors for a secure connection between panels. If mixed up (e.g., replaced with longer screws), they will not properly engage with the material, and the connection will loosen over time.
- Longer screws (e.g., 30–50 mm (1.2–2 inches) in length) are used for side panels, back panels, and load-bearing elements. These often have a coarser thread and are designed so they do not split the panel material. Using shorter screws here compromises stability; using screws that are too long risks material damage or penetration through the panel.
- Hinge screws are often shorter with special threads designed for metal plate hinges. Using the wrong screws here can cause doors to fit poorly.
Another common pitfall: Some screws in the set look very similar but differ by just a few millimeters (in length). Therefore, always measure before assembly and carefully follow the instruction manual.
I recommend checking the screws with a caliper before assembly to avoid mix-ups. Sometimes it helps to sort the screws into small containers or labeled compartments to keep track during assembly.
Finally, one question: Which version or variant of BESTA are you assembling, and do you have all the original screws from the set or are you working with replacements? This can significantly affect the risk of choosing the wrong screws.
