ᐅ Which screwing techniques improve the stability of BILLY?
Created on: 17 Feb 2024 19:42
lilukin
lilukin
17 Feb 2024 19:42
I am currently working on assembling my BILLY bookshelf and want to significantly improve its stability. Besides the standard chipboard screws typically used, I am wondering which fastening techniques actually make a measurable difference. Specifically, I am interested in whether pre-drilling holes or using wall plug anchors increases stability, or if there are special methods that should be applied with BILLY.
It would also be helpful to know if reinforced techniques can be used at critical points, such as the connections between the shelves and the side panels or the back panel, to prevent wobbling and warping over time.
Maybe someone here has experience with such modifications or knows technical solutions beyond the official instructions. I look forward to specific tips and explanations, including advice on tools and screw types that should preferably be used.
Thank you in advance!
Elijah42
17 Feb 2024 20:07
Pre-drilling is definitely advisable to prevent the wood from splitting and to ensure a better grip for the screws.
Additionally, using dowels is particularly helpful in load-bearing joints, as this increases tensile strength.
For the connections between the shelves and the side panels, I always use additional corner brackets to enhance stability.
fredle
18 Feb 2024 08:14
Regarding the question of which screwing techniques can significantly improve the stability of a BILLY bookshelf, I would like to provide a brief guide:
1. Pre-drilling:
Pre-drilling is the first essential step. It prevents cracks in the chipboard material and ensures the screws sit straight and firmly.
2. Screw type:
It is best to use chipboard screws with coarse threads and ideally a Torx head. These provide better grip and reduce the risk of stripping.
3. Dowel technique:
Insert plastic or metal screw-in dowels at the load-bearing connections. This helps to distribute the load more evenly on the wood.
4. Angle brackets:
Especially in the corners (where side panels and the back panel connect), small metal angle brackets can be additionally installed. Make sure to use screws of appropriate length to avoid damaging the panels.
5. Retightening:
Check the assembly after a few days and retighten the screws if necessary, as the material may settle over time.
Common mistakes include screwing directly without pre-drilling or using screws that are too long, which can damage the back panel.
In summary: Combining pre-drilling, suitable coarse-thread screws, dowels in key locations, and angle brackets significantly increases stability.
If desired, I can provide tool recommendations later.
kulau
19 Feb 2024 16:23
I would like to add that the structural stability of BILLY shelves is often underestimated, especially when the shelf is taller or wider than the standard model.
fredle schrieb:
Pre-drilling is the first step that should definitely be done.
That is an important point. Additionally, I recommend drilling with a wood drill bit about 2-3 mm (approximately 0.1 inches) shallower than the length of the screw, so the screw doesn’t spin in the hollow space and achieves optimal grip.
For attaching the shelves to the side panels, I often use wood glue as well, which reinforces the form-fit connection.
Elijah42 schrieb:
I always use additional angle brackets at the joints of the shelves to the side panels
Angle brackets are stable but not to everyone’s aesthetic taste. An alternative method is using metal plates with multiple fixing points that are screwed underneath the shelves to secure them.
Adding threaded inserts to the end panels can also help, allowing screws to be loosened and tightened multiple times without damaging the material.
Has anyone had experience with alternative screwing techniques, such as pocket holes or biscuits (Lamello joints), with BILLY shelves? I would be interested to know if that is practical.
In general, I recommend driving screws carefully using a torque wrench or at least a variable-speed cordless drill to avoid over-tightening.
That’s my perspective for now – if needed, I can also share information about the tool kits I personally use for such tasks.
tutan
19 Feb 2024 21:04
I find that assembling BILLY is even more enjoyable when you spice up the screwing technique a bit. 😉
kulau schrieb:
Has anyone had experience with alternative screwing methods, such as pocket holes or Lamello joints, in BILLY shelves?
I have actually used pocket hole screws to reinforce the connection between the side panels and shelves. It works great if you drill a few small holes at the back, which you can later cover with a back panel anyway. This creates concealed joints that are really strong without any visible metal brackets.
I would still recommend pre-drilling, otherwise the screws wear out quickly. If you also assemble the entire shelf with wood glue, you can expect a fairly durable piece of furniture.
And since we’re on the subject of screwing techniques: I like to use countersunk screws because they can be sunk flush and make planing easier if you want to sand or refinish the surface later.
For those looking to vary the screwing routine: I can also recommend Torx screws. They offer better grip and you’re less likely to slip with the bit. 🙂
