ᐅ Which screw fastening techniques are recommended for assembling BILLY shelves?
Created on: 30 Jul 2018 09:14
glaron
Hello everyone, I want to assemble a few Billy shelves and am unsure which fastening techniques are most recommended. IKEA provides screws and wall plugs, but I wonder if it might be more effective to use additional methods or different types of screws to improve stability or to make assembly easier and more durable. I am especially interested in techniques that have proven effective when installing multiple shelves side by side or in corners. Are there any tips for pre-drilling, gluing, or specific screw types that should be preferred? I’m also curious about the required torque and whether a cordless drill or manual tools are better to use. I would appreciate all experiences and recommendations!
glaron
1 Aug 2018 07:58
Thanks to all of you for the great tips!
I will pre-drill and countersink the holes slightly, use fine-thread screws, and also apply wood glue. For the connections between the shelves, I will use metal brackets and possibly wooden battens at the back to prevent tipping.
Does it make sense to also fix the shelves to the floor, or are the wall fastenings and connections sufficient?
Thanks again for your help!
tangi
1 Aug 2018 08:20
glaron schrieb:
Does it make sense to secure the shelves to the floor as well?
If the floor is level and non-slip, usually fastening the shelves to the wall along with connecting the shelves to each other is sufficient.
However, if there are children in the household or if movement is expected, securing the shelves to the floor is an additional safety measure, for example using small non-slip furniture pads or screw-on brackets.
This provides extra stability and helps prevent tipping when force is applied from the front.
In typical residential settings, it is often not strictly necessary.
LEVI41
1 Aug 2018 08:47
From a technical perspective, I strongly recommend securing the shelves to the wall, as they can tip over under load otherwise.
Fixing to the floor mainly serves as additional safety but is rarely necessary if both the wall and floor are level.
All screws should be placed at a sufficient distance from the edges to prevent material cracking. With BILLY shelves, special attention should be paid to the specific screw holes to ensure stability is not compromised.
tutan
1 Aug 2018 09:03
Finally, my last tip: When screwing in, don’t apply too much pressure on the cordless drill – it’s better to tighten the screw multiple times with less force rather than driving it in quickly at high speed. This helps prevent material damage. 😉
And as always: Good luck and enjoy your finished shelves! 🙂
