ᐅ Which types of screw connections do you recommend for assembling Ikea PLATSA?
Created on: 2 Jan 2015 10:22
KnudkaHello everyone,
I am currently planning my Ikea Platsa furniture set and intend to connect the individual modules to create a larger wardrobe. I am wondering which screw connections you would recommend for joining Ikea PLATSA modules.
My main concerns are stability and durability, as I would like to be able to move or expand the wardrobe in the future. Should I rely on the original Ikea connection screws when assembling, or are there better alternatives available from hardware stores?
I am also interested in whether you can recommend any specific types of screws or reinforcement techniques to prevent accidental loosening without affecting the appearance.
I look forward to your tips and experiences, especially if you have worked with similar furniture before!
Regarding which screw connections are recommended for Ikea PLATSA, I primarily suggest the following approach:
- Use the original fastening elements from Ikea. These are optimally matched to the material and construction of the PLATSA modules.
- For additional stability, Spax screws (20-30 mm long, 4-5 mm diameter) can be used in hidden areas, such as inside the modules or on the back panel.
- It is important to ensure the screws do not go directly into edges or joints to avoid material cracking.
As an alternative to standard screws, screws with locking ribs or self-locking threads can be used to reduce loosening caused by vibrations. However, for moves or frequent reassembly, I recommend using connections that can be easily undone, so avoid screws that are too strongly self-locking.
One final tip: if stability is the main concern, metal angle brackets can be added and screwed into the inner corners. Although these are visible, small cover caps can be used to conceal them.
vinli schrieb:
As an alternative to standard screws, screws with locking grooves or self-locking threads are recommended to minimize loosening caused by vibrations.This is a very important point that I would like to add! Especially for furniture that is frequently assembled and disassembled, it is worth using these types of screws—particularly if you move often.
Regarding assembly of the PLATSA system itself: There are definitely cases where it makes sense to use glue if you want to connect the modules firmly. If that is not desired (e.g., for later modifications), then you need to rely on solvent-based adhesives that allow for easier separation.
A small tip: For Ikea PLATSA, the connection holes are quite precisely positioned, so when choosing screws, it’s best to select those with the smallest possible diameter to adapt the furniture without causing damage.
Interesting discussion here, I’d like to add some technical details:
The Ikea PLATSA series is based on a carcass made of finger-jointed particleboard, and connected surfaces are mainly secured with Minifix dowels and wood screws.
If you want to maximize the stability of the screw connections, you should pay attention to the following:
- The screw length must not exceed the thickness of the panels, otherwise there is a risk of splitting or pulling out.
- In addition to the original screws, use metal brackets (e.g., 40x40 mm (1.6x1.6 inches)) inside for reinforcement if the furniture needs to carry heavy loads.
- Especially for connections between two PLATSA modules, it is advisable to use cam lock screws (Minifix) with matching dowels, which securely connect the modules and can be disassembled if needed.
In my experience, the original connecting components are designed for typical loads and better integrated into the system.
However, if you plan to significantly modify the furniture (different material, different dimensions), it is possible to use stronger screws from a hardware store, but please make sure to pay close attention to drilling patterns and materials to avoid cracks.
Could you describe in detail which loads or usage scenarios are planned? Then I can provide more targeted recommendations.
Knudka schrieb:
Should you rely on the original Ikea connecting screws for assembly, or are there better alternatives from hardware stores?
Knudka schrieb:
I’m looking forward to your tips and experiences, especially if you’ve worked with similar furniture before!I completely understand your caution—I once assembled a PLATSA wardrobe and had to tighten the screws quite often afterward. From that, I learned that it’s not so much the screws themselves, but rather the firmness of the connections that matters most.
Personally, I used the original screws but added small plastic washers to increase friction slightly, which helped prevent the screws from loosening as often.
It might not be the most scientifically precise method, but in everyday use, the furniture felt much sturdier this way. So, if you frequently move or modify it, I wouldn’t recommend extremely long or oversized screws. Instead, I’d rely on the combination of screws plus a mechanical aid (such as washers or even a small amount of wood glue at the contact points).
And don’t worry—tightening screws now and then is normal. I hope this helps you a bit, and good luck with your PLATSA project!
