ᐅ Which screw connections in IKEA Hemnes furniture are most prone to issues?
Created on: 9 Apr 2015 18:12
Sisi47
Hello everyone, some time ago I put together a few pieces of furniture from the IKEA Hemnes series, but now I am a bit uncertain about the screw connections. My specific question is: Which screw connections or particular types of joints in the Hemnes furniture are especially prone to issues such as loosening, material damage, or loss of stability? For example, I mean the connection of the cabinet doors or the attachment of shelves to the side panels. I am especially interested in long-term experiences and advice on where to be particularly careful during assembly or everyday use to keep the furniture as durable and stable as possible.
SARBLA1
10 Apr 2015 08:22
Hello Sisi47, as a general recommendation, it is best to use torque screwdrivers on a low setting to avoid overtightening. For the Hemnes furniture, standard Phillips screwdrivers with a good fit for the screws are also very useful.
When retightening, it is advisable to first check gently if the joints are loose. If they are, carefully tighten the screws, but only about half a turn. Retightening too often is not recommended; it is better to check in intervals of 6 to 12 months.
Additionally, during assembly, it is often helpful to apply a small amount of wood glue before inserting the dowels, as this significantly strengthens the joint.
teo33
10 Apr 2015 09:10
With Hemnes furniture, the small screws that hold the drawer slides are often a source of problems. If the drawer is heavily loaded, these screws can pull out. It is recommended to use replacement metal screws with a larger diameter if necessary.
Sepele
10 Apr 2015 09:55
I will summarize the topic in a structured way:
1. The main problem areas are the joints in the back panel, which are often held together only with thin nails or small screws – these tend to loosen under stress or movement.
2. The door attachments to the side panels via hinges use screws in particleboard – overtightening quickly causes them to strip or pull out.
3. The connection of the side panels to the shelves is usually done with wooden dowels and expansion screws, which can tear out if overtightened.
My recommendations:
- Tighten screws only by hand, avoid using excessive force.
- Apply wood glue in the dowel holes for better grip.
- Check regularly and gently retighten if necessary.
Common mistakes are overtightening and using incorrect tools. Following these tips will result in significantly fewer issues with the Hemnes furniture.
GLORIA
10 Apr 2015 10:33
In summary, the Hemnes furniture from IKEA, constructed mainly from veneered particle board combined with simple mechanical fasteners, shows increased susceptibility to failure at screwed connections.
Particularly affected are:
- Screw fixings of hinges on the doors
- Dowel joints between side panels and shelves
- Fastenings of the back panel (usually thin nails or small screws)
For long-lasting stability, proper assembly is therefore essential.
- Avoid overtightening screws
- Use wood glue with dowels
- Regular, gentle inspection of connection points
These measures significantly reduce splitting and loosening.
sonrickey
11 Apr 2015 11:40
Sepele schrieb:
Typical mistakes are overtightening and using the wrong tools.
Exactly! And if I may add a tip: When tightening any screw connections, take a brief moment to pause and turn the screws gently. This helps prevent annoying creaking noises and looseness.
Basically, tighten screws with care and patience – that way, your Hemnes treasures will last a bit longer 😉.
