ᐅ Which replacement hinges can be used with Ikea BESTA units as a durable alternative?
Created on: 20 Mar 2023 09:14
keomitchel
Hello everyone, I have a somewhat detailed question regarding the Ikea Besta series. Some of the door hinges in our units have proven to be less durable, which is a bit disappointing given the frequency of use. Therefore, I would like to know: which replacement hinges can be installed in Ikea Besta as a more durable alternative, that fit functionally and offer significantly better longevity? It would be great if you could share your experiences or tips on specific brands, hinge models, or modifications. I am especially interested in compatible options that are easy to install without requiring major alterations to the furniture. Thanks in advance for your well-informed recommendations!
anfeteo schrieb:
If necessary, slightly enlarge or redrill holes, paying attention to the correct screw size I would like to point out that many users usually don’t need to modify drilling holes for Hettich or Blum hinges if the measurements match. The original Ikea Besta units use standard sizes. However, if you want to use other inexpensive replacement hinges, it is essential to check the measurements before installation.
Equally important is the choice of screws: Whenever possible, use the original screws from the manufacturers, as they are specifically designed for the material of the doors and carcass as well as for load distribution. Cheap screws can reduce stability and durability.
keomitchel21 Mar 2023 14:37Jeanbar schrieb:
Gladly, I can recommend the Hettich Sensys concealed hinges, especially the model with a 35 mm (1.4 inch) cup diameter Hello everyone, I just wanted to take a moment to thank you again. Based on your advice, I will most likely go with the Hettich Sensys model. The combination of easy installation and improved soft-closing is decisive for me. I will carefully measure the door thickness beforehand to confirm it is really the recommended 16–22 mm (0.6–0.9 inch), and I will prepare the installation according to the instructions from anfeteo. If I have any questions after the installation, I’ll be happy to reach out again.
