ᐅ What repairs can I do myself on IKEA Hemnes furniture?
Created on: 9 Sep 2021 18:37
Juris7
Juris7
9 Sep 2021 18:37
Hello everyone, I have some furniture from the IKEA Hemnes series and am considering which repairs a moderately skilled DIYer can manage without having to call a professional. Specifically, I am interested in whether there are common weak points in Hemnes furniture that can be repaired or reinforced by oneself, such as loose screws, hinges, swollen wood parts, or damaged surfaces. I would also like to know how time-consuming these types of repairs usually are and which tools and materials it is advisable to have on hand. Are there any tips on how to determine if a repair is worth doing at all, or if replacement would be a better option? Thanks in advance for your insights and experiences!
Kenon70
9 Sep 2021 18:44
Typical repairs for Hemnes furniture usually involve tightening or replacing screws and fittings. Minor scratches can be touched up with wood repair markers. For swollen areas, light sanding followed by a wood sealant helps. Misaligned drawer slides can often be easily adjusted by repositioning the screws. Replacement parts are often available directly from IKEA.
Domau0
9 Sep 2021 20:02
Your question hits the core well, as the Hemnes series mainly consists of solid pine wood components, which are sturdy but can be sensitive to moisture. The most common DIY repair is tightening screws, especially on drawers or doors, since the wood-to-metal connections tend to loosen over time. To do this properly, I recommend the following steps:
- Completely unscrew the hardware screws and check for any damage.
- Replace screws as needed with ones that are not too long or too short (ideally matching the original screw size).
- For enlarged holes, drill new pilot holes or stabilize them with wooden dowels instead of worn-out holes.
For swollen areas, usually caused by moisture, you can often fix them by gently sanding and then sealing with clear varnish or wood oil. If the surface is heavily damaged or deeply cracked, it’s worth assessing whether replacement parts are needed. Hinges and drawer slides can usually be adjusted without special tools and lubricated with a product like WD-40 if they squeak or stick.
Important to consider: If load-bearing wooden parts are severely swollen or split, you should not just make cosmetic repairs but rather replace them to maintain the furniture’s stability. In terms of tools, you’ll need a suitable Phillips and flathead screwdriver, a cordless drill for screws and drilling, sandpaper (grit 120-240), and wood care products.
I’m curious whether you have moisture-related damage and which specific parts of the Hemnes are affected? That way, I can offer more targeted advice.
bulanau
10 Sep 2021 08:15
Here is a brief guide for repairing IKEA Hemnes furniture on your own, based on the most common issues:
- Loose screws: Remove all screws in the damaged area and check the drilled holes. If they are too large, fill them with wood filler or wood putty and wait until it is dry. Then carefully pre-drill and tighten the screws.
- Adjusting hinges: Most Hemnes hinges have adjustment screws. These can be carefully adjusted with the appropriate screwdriver to realign the doors.
- Surface repairs: Small scratches or finish damage can be fixed using wax sticks or repair kits. For larger damage, consider light sanding and resealing.
- Drawer tracks: If the drawer sticks, first clean the guide rails and check if they are properly aligned. You may need to tighten or slightly reposition the screws.
Common mistakes to avoid:
- Over-tightening screws, which can cause cracks in the wood.
- Sanding with too much pressure, which can damage the surface.
In summary: these tasks are manageable with patience and the right tools. For load-bearing parts or extensive damage, I recommend a professional assessment. Good luck!
glamo
10 Sep 2021 19:54
First of all, I think it’s great that you asked your question in such detail. Hemnes furniture really provides a solid foundation for DIY repairs, as long as certain principles are followed.
With loose screws, you can often start by checking that the screws are firmly seated. This requires the underlying wood structure to be intact. If the wood is worn out, you can do the following:
- Remove the screw and temporarily fill the hole with a piece of wood or wood glue and wood shavings to restore stability.
- After drying, the hole can be carefully pre-drilled to the screw size.
It is important not to blindly try to tighten all parts but to carefully check the condition of the wooden components.
Surface damage is usually cosmetic and can be fixed by sanding, cleaning, and re-treating with stain and varnish. Keep in mind that swollen wood is often caused by moisture—make sure to remove the source of moisture; otherwise, the repair will only be temporary.
If the drawer runners are sticking, also check whether screws on the runners have loosened or the sliding rails are bent. Replacement parts such as hinges and screws can be purchased directly from IKEA or at a hardware store.
An important question: Which pieces of furniture are affected exactly? Desk, dresser, bed? Depending on the load, repair options can vary in feasibility.
