ᐅ What problems are most common when assembling the Ikea Brimnes?
Created on: 14 Oct 2020 18:22
August9
August9
14 Oct 2020 18:22
I am currently planning to assemble the Ikea Brimnes wardrobe and would like to learn about common issues that occur during the assembly process. Specifically, I am interested in difficulties related to the instruction manual, the fit of the parts, or any tools that might be needed. It would be especially helpful to get advice on areas where fitting problems frequently happen or on assembly steps that many find complicated.
Does anyone know typical pitfalls when building this piece of furniture that can be easily avoided? Are there any special tips for organizing the parts or the workflow that make the assembly noticeably easier? Thanks in advance for your experiences and advice!
tolokau
14 Oct 2020 19:08
Hello August9,
when assembling the Ikea Brimnes wardrobe, several recurring issues have come up that I would like to summarize here in an organized way:
- Instructions: The step-by-step descriptions are generally clear, but some detailed drawings are missing, especially regarding the connection of the back panels to the carcass. This can easily lead to confusion if you don’t compare carefully.
- Fit: Some of the pre-drilled holes are not always precisely positioned. This makes fitting the back panels or hinges a bit fiddly when screws don’t align exactly. It helps to roughly assemble the parts before screwing to check the alignment.
- Back panels: These are often a bit tight in the frame, so inserting them requires some patience and gentle force without applying too much pressure, as the material can be easily damaged.
- Hinges: For the doors, it’s best to first loosely attach all the hinges, hang the doors, and then tighten the screws fully. This way, you can fine-tune the door position if they don’t hang perfectly straight.
- Tools: Usually, only a Phillips screwdriver is needed, but if you have a cordless drill with torque control, it can make the job much easier. Just be careful not to overtighten the screws.
My tip: Work through the parts systematically and sort all screws by size beforehand. Don’t follow the instructions too hastily; if something is unclear, check the corresponding part freehand instead.
I hope these notes help!
roryvin
15 Oct 2020 08:37
tolokau schrieb:
Fit accuracy: Some of the pre-drilled holes are not always precisely positioned.
This observation is accurate. A frequently underestimated issue is the slight imprecision in manufacturing, as the accurately drilled holes are sometimes slightly offset, making the exact installation of the back panels more difficult.
Additionally, the following should be noted:
- Installing the doors requires precise adjustment, since even minor deviations can cause the fronts to appear misaligned.
- Brimnes drawers occasionally experience problems with the sliding rails, which do not always operate smoothly during initial assembly.
- The installation of the long handles also demands exact measuring to ensure they sit flush and straight afterward.
Conclusion: Care and time spent aligning the components will prevent issues later on. It is recommended to prepare and measure the parts before final screwing. A ruler and level are very helpful for this.
WARREN
15 Oct 2020 09:43
Many people have difficulty installing the back panels without causing damage. Work carefully and try small levering movements.
Also, tighten the screws only loosely at first to allow better adjustment of the doors.
tolokau
16 Oct 2020 14:59
WARREN schrieb:
Loosen screws slightly first to better adjust the doors.
This is exactly a key point with Brimnes. A rigid, inflexible installation makes later adjustments impossible and quickly results in misaligned door fronts.
Another tip I’d like to add: when assembling the drawers, the runners may not fit perfectly. To ensure the drawers operate smoothly, check before assembly that the guides move freely without resistance. If not, it’s advisable to slightly loosen the screws and realign the runners.
A note on the back panels: since they are rather thin, avoid applying excessive force during installation to prevent dents or breaks.
Finally, organizing the parts is crucial for an easy assembly: sorting screws, dowels, and small connectors in advance saves unnecessary searching during the work.
