ᐅ Which furniture pieces complement the Ikea Brimnes series best?
Created on: 28 Oct 2024 19:27
MaratHello everyone,
I am currently planning to furnish my bedroom with the Ikea Brimnes furniture, specifically the bed and the dressers. Now I am wondering which other pieces would best complement Brimnes, both from Ikea and possibly from other brands. It is important to me that the style remains harmonious but also practical: storage space, simplicity, and a certain modern look.
Are there any furniture pieces that particularly match the Brimnes design well, either from the same series or compatible in style and function? What about additional storage solutions, nightstands, or wardrobes? I look forward to your recommendations, including tips on color choices or important details when combining them. Thanks in advance!
Hello Marat,
When combining with Ikea Brimnes, it is especially important to maintain the typical clean lines and functional aspects of the series. You already have the bed and the dressers – a great start! To complement these, I recommend:
- Nightstands from the Brimnes series itself, as they match perfectly in color and depth and provide extra drawers.
- If you need a wardrobe, the Pax wardrobe with white, smooth fronts is ideal since it supports the clean look and is very flexible inside.
- For additional storage, a simple white Kallax shelf can be a good option. Its open compartments complement the Brimnes series nicely without looking too bulky.
Important: When choosing colors, make sure the whites and shades of white match. Sometimes white tones differ, which can disrupt the harmony. Personally, I always compare furniture in daylight.
One more practical tip: Pay attention to even anchoring to the wall during assembly, especially with taller cabinets, as uneven floors often cause problems. Although Brimnes is quite sturdy, wall mounting makes everything safer.
How are your room dimensions? Then I might be able to offer more specific suggestions, especially regarding storage solutions.
Domau0 schrieb:
Make sure that the whites and white shades you choose are consistent.This is a very important point, which I can only emphasize. I want to approach the topic a bit more systematically. For everyone planning to combine furniture pieces, I have put together a practical guide to ensure that IKEA Brimnes is complemented optimally:
1. Color analysis: IKEA often uses the color codes “pure white” or “off-white” for white. To achieve a uniform overall appearance, ideally choose identical color names or compare the furniture in person.
2. Matching series:
- Brimnes nightstands are naturally the safest choice, especially if you want the same material and height.
- Series like Malm can also work, but they often have softer edges and slightly different wood grains.
3. Storage principles:
- Opt for furniture that combines different types of storage (drawers, shelves, closed doors) for maximum flexibility.
4. Style:
- Brimnes is rather modern and functional, so complementary furniture should also have clean lines and be sturdy.
5. Alternative brands:
- If it doesn’t have to be IKEA, furniture in Scandinavian style with white lacquer or light wood matches well.
One common mistake is mixing different shades of white, which quickly looks inconsistent.
A quick note on nightstands: Brimnes models offer the advantage of visually connecting with the bed, especially if you need extra storage.
I hope this helps you plan better. If you want, you can also send me your room measurements, and I can suggest how to make best use of the space.
