ᐅ Which parts of the IKEA Brimnes wardrobe are most prone to damage?
Created on: 23 Jul 2021 18:24
neta66
neta66
23 Jul 2021 18:24
Hello everyone, I am currently focusing on the durability and sturdiness of the IKEA Brimnes wardrobe, especially regarding potential weak points that are particularly prone to damage in everyday use. Specifically, I am interested in which parts of the IKEA Brimnes wardrobe are most susceptible to damage and why.
I am not only referring to obvious aspects like the doors or drawer fronts but also less visible components such as connectors, shelves, or fittings. It would also be interesting to know whether material properties or the construction contribute to certain weaknesses.
Perhaps you have experience from use or assembly that shows which parts are subject to higher stress or wear out faster. Or maybe there are general tips on how to avoid or reinforce specific weak points. Thanks in advance for your insights!
Saramar
23 Jul 2021 19:02
The shelves are often the most vulnerable, especially when they are overloaded. Drawer slides are also weak points, as they can wear out quickly with frequent use.
Doors, on the other hand, are solid as long as the hinges are properly installed.
meGreg
23 Jul 2021 20:07
I have been using my Brimnes for two years now – and yes, the small plastic clips that hold the back panel have broken several times. Very annoying! 😅
Saramar schrieb:
The shelves are often the most vulnerable, especially when overloaded.
Exactly, if there is too much weight, the shelves bend, which becomes noticeable quickly. So it’s better not to stack very heavy items on them, otherwise it turns into something like a hammock.
pikin
24 Jul 2021 08:33
For additional information: The construction of the Brimnes wardrobe uses overlay hinges and shelves made of particleboard with a melamine coating. The primary risks are:
- Shelves: Due to the particleboard material and lack of reinforcement, they may sag under excessive loads.
- Back panel fixation: The thin back panels made of hardboard are held in place with plastic clips, which can break if incorrectly installed or due to material fatigue.
- Drawer slides: Metal runners with plastic components can wear out or loosen with frequent use.
These parts are the most critical due to the materials used. It is generally recommended to limit the loads on the shelves and to follow the assembly instructions precisely to avoid overstressing the clips and hinges.
Dirkmin
24 Jul 2021 10:15
meGreg schrieb:
The small plastic clips that hold the back panel have broken several times for me.
These back panel clips are indeed common weak points. They can be easily damaged if the back panel is installed carelessly or if the cabinet is assembled on an uneven surface.
The surfaces of the drawer fronts also tend to get scratched over time, which mainly affects the appearance rather than the function. Another issue is that the bottom supports can loosen if the cabinet is placed on carpet and moved.
In summary, careful assembly and gentle handling of the shelves and back panel clips are crucial for maximum durability.
