ᐅ Which types of paint provide durability and aesthetic appeal for Ikea Besta furniture?
Created on: 6 Dec 2019 09:27
NAKONSTA50N
NAKONSTA506 Dec 2019 09:27Hello everyone,
I am currently planning to upgrade my IKEA Besta furniture and am wondering which paints work best when it comes to a combination of durability and aesthetics. Specifically, I am looking for a paint that not only looks high-quality but also creates a long-lasting protective layer that can effectively resist scratches, moisture, and everyday wear.
My Besta units are currently white, but I am open to repainting them, possibly with a color or finish that combines elegance and durability. It is also important that the paint adheres well to the MDF surfaces and does not peel or get damaged over time.
Does anyone have experience with certain types of paint—such as acrylic, polyurethane (PU), or acrylic-based paints—and can offer recommendations on which products or brands are particularly suitable? Any tips on surface preparation are also welcome.
Thanks in advance for your expert advice!
In general, I recommend using high-quality 2-component polyurethane (PU) coatings for furniture pieces like the IKEA Besta that are frequently subjected to wear. Compared to acrylic or standard coatings, these offer better resistance to scratches, impacts, and moisture. They also provide high color brilliance and durability.
It is important to sand and clean the surface thoroughly before painting to ensure optimal adhesion. Primers or adhesion promoters specifically designed for MDF make it easier to apply the coating evenly and prevent later peeling.
It is also worthwhile to apply an intermediate sanded layer – this results in a particularly even and smooth finish.
For furniture that gets heavy use, I would rather opt for satin or matte finishes, as high gloss shows scratches and fingerprints more easily.
Hi everyone,
Some time ago, I refreshed my Besta combination furniture with a one-component acrylic paint – and it looks really great! Will it last forever? No idea, but so far no scratches or chipping after two years. 😎
The big advantage of acrylic is that it’s easy to work with, dries quickly, and is also great for DIY painters.
That’s true, PU paints are more durable, but they are also more complex to apply and come with stronger odors. For anyone who doesn’t want to have their furniture professionally repainted, acrylic paint is a solid alternative.
A little tip: Always apply several thin layers rather than one thick one. This prevents runs and improves the final result. 😉
KIN42 schrieb:
Basically, I recommend using high-quality two-component PU (polyurethane) paints for furniture like the IKEA Besta, which is often subjected to heavy use.
Additional information:
The choice between 1-component (1K) and 2-component (2K) coatings should depend on the application and requirements. 2K polyurethane (PU) coatings chemically react after mixing two components, resulting in a significantly harder and more durable surface. In contrast, acrylic coatings (1K) dry physically and are less resistant to mechanical stress.
From a technical perspective, the following points should be considered:
- Adhesion: MDF requires pretreatment with a primer or adhesion promoter
- UV stability: If furniture is exposed to strong light, this affects color fastness
- Chemical resistance: PU coatings are more resistant to cleaning agents
- Workability: 2K coatings require precise mixing and appropriate equipment
For those prioritizing quality and long-lasting aesthetics, 2K PU coatings are recommended, provided the user has the necessary skills or obtains professional assistance.
I can well imagine that many here feel the same way I do: You face the decision of how much effort to put into improving the furniture but are unsure what is worthwhile. It’s great to read such well-founded advice here!
This resonates with me, especially since MDF is often not easy to work with. For me, an environmentally friendly solution would also be interesting. Has anyone had experience with water-based PU coatings that provide good protection but produce less odor and environmental impact?
I think it’s also a matter of finding the right balance between effort, results, and sustainability. It’s nice to see different perspectives here!
NAKONSTA50 schrieb:
It would also be important that the paint adheres well to the MDF surfaces and does not peel or get damaged over time.
