I am planning to paint my Ikea Besta furniture myself and would like to gather detailed information about suitable types of paint beforehand to achieve the most durable and optimal results. My main question is: Which paints are best suited for the surfaces of Ikea BESTA furniture?
I am especially interested in which paint types (e.g., acrylic paints, alkyd paints, spray paints, chalk paints, etc.) adhere well to the mostly smooth, melamine-coated surface without peeling or cracking.
Does anyone have specific product recommendations or tips for surface preparation (sanding, priming) as well as information on paint properties such as abrasion resistance and color retention for this furniture series? Are there also experiences with different application techniques (rolling, spraying, brushing)?
I am particularly looking for long-lasting solutions, as the BESTA fronts in my living room get a lot of use. I appreciate any tips based on long-term experience or current product recommendations. Thank you in advance!
Sinon schrieb:
Which paints are best suited for the surfaces of Ikea BESTA furniture?Basically, the BESTA fronts are either melamine-coated or foil-covered, meaning the surface is quite smooth and somewhat hard, which makes paint adhesion more difficult.
From my experience and common recommendations, the following paints work best:
- Acrylic paints, especially water-based ones, because they dry flexible and are less prone to chipping
- 2K (two-component) synthetic resin paints, which are very durable but somewhat more complex to apply
Proper surface preparation is always crucial:
- Thorough sanding with fine sandpaper (around grit 220–320) to slightly roughen the surface
- Cleaning to remove dust and grease
- For some projects, a special plastic primer or adhesion promoter suitable for melamine is recommended
For application, I prefer spray paints because they provide an even, smooth finish without brush marks. Rolling is also possible but requires high-quality rollers with a very fine texture—brushes are generally less professional as they leave visible marks.
Regarding durability: The thicker and more even the paint is applied, the better. 2K paints are really resistant for everyday use, though they are a bit more expensive and require protective gear (mask) during application.
If you want to learn more about the individual steps, just ask!
nikian schrieb:
The proper preparation of the surface is always the key pointI agree with that, and I think it’s the crucial factor if you want to do your own painting.
From my workshop experience, I can give you the following detailed advice:
- Melamine surfaces are extremely smooth and durable due to the so-called thermo-fusing process. That’s why mechanical pretreatment is even more important.
- For years, I have been using a sanding method on IKEA furniture with a sanding pad (such as Siaair or Norton Radialpad) with a grit of about 320, to create a very even surface that does not leave scratches as adhesion points but promotes paint adhesion.
- After sanding, a thorough degreasing with suitable alcohol (isopropanol or similar) follows, since regular cleaning cloths often leave residues.
Regarding paints, in my opinion, there are two main candidates:
- Two-component polyurethane paints: they offer the best scratch and impact resistance but are more demanding for DIYers because of mixing and working times.
- High-quality acrylic paints with curing components or PU additives that create a more robust surface.
One point many overlook: the application temperature should ideally be around 20°C (68°F), otherwise, bubbles or poor adhesion can occur.
For application:
- Spray paints are optimal, but good ventilation is essential.
- With a good paint roller (e.g., microfiber roller with 4-6 mm (0.16-0.24 inch) nap), you can achieve very good surfaces even without airbrushing.
- I would only recommend brush painting for edges, as it otherwise tends to become very uneven.
Consider also whether you want the surfaces matte or glossy; two-component paints are available in both versions, with different drying times and impact resistance.
What colors are you thinking of? Do you want to keep the original shade or change it entirely?
In any case, good planning and testing on a small area are mandatory. Otherwise, I’d also recommend obtaining a sample from a specialist dealer if possible.
Sinon schrieb:
Which paints work best for the surfaces of Ikea BESTA furniture?This question is actually quite difficult to answer because the BESTA surfaces with their melamine coatings are really resistant to many types of paint.
I have personally tried several types of paint and can say that patience and thorough preparation are essential.
My advice is not only to focus on the paint itself but also to be mentally prepared for the outcome, as the project may require several attempts before achieving optimal adhesion.
In my several-month-long tests, the following points proved helpful:
- Using primers specifically designed for plastics or melamine (these are not always easy to find but definitely worth it)
- Using acrylic or polyurethane paints, as they offer some flexibility, which helps prevent cracking
- Flexible stains can also be interesting if you want a translucent finish
It helped me to allow the parts to cure for several days between coats to avoid stress in the paint layer.
I think it’s important to enjoy the process and not see any mistakes as failures but rather as part of the learning experience. If you need specific paint product names, I’m happy to share some.
NICOLELIS12 Dec 2015 12:06PIN66 schrieb:
In my opinion, there are two main contenders when it comes to paints:I agree with that.
In short:
- Acrylic paints are suitable for beginners
- 2K polyurethane paints are better for durable surfaces
With careful sanding (320 grit or finer) and a good primer, it usually works well. Spray paints provide a nice finish, but depending on the project, rollers can also be used.
If you want a specific product recommendation: look for brands that offer 2K paints specially formulated for furniture or melamine surfaces, such as those from Sikkens or Clou.
