ᐅ Which paints are durable and long-lasting for IKEA Besta furniture?
Created on: 14 Sep 2015 18:23
bumereHello everyone,
I am currently planning to upgrade my IKEA Besta furniture and am considering which paint or finish would be best to make the piece especially durable and long-lasting. Since the surfaces of Besta are usually quite smooth and made of laminated panels, I’m wondering: which type of paint or finish adheres best and holds up well under frequent use and stress?
I’m particularly interested in a coating that combines scratch resistance with strong adhesion to the surface. At the same time, it should have an attractive appearance and not yellow or peel easily.
Does anyone have experience with specific types of paint or recommendations on what works well for IKEA Besta furniture? Whether acrylic paint, polyurethane, water-based finishes, or something else—I would appreciate any advice, including possible surface pretreatments that could improve durability.
Thanks in advance for your tips!
Hello bumere,
That’s a very good question, which requires quite a bit of background knowledge when assessing the durability of paints on IKEA Besta units. Generally, the surfaces on Besta are either melamine-coated or covered with a smooth laminate, which makes paint adhesion more challenging.
Regarding durability:
- Polyurethane resin paints (PU paints) are extremely resistant to scratches, chemicals, and moisture. They provide a very hard surface and are often preferred in the furniture industry when long-lasting results are needed. However, they usually require thorough surface preparation, such as light sanding, to ensure optimal adhesion.
- Acrylic paints, on the other hand, are usually more environmentally friendly and dry faster, but they don’t always offer the same hardness and scratch resistance as PU paints. For Besta, they might be sufficient if the surface is not subjected to heavy wear.
- Water-based paints are modern and less harmful to health, but they are mostly used on wooden furniture and may not adhere well to laminate surfaces.
Proper preparation is crucial: before painting, you should always clean the surface thoroughly, use the right sandpaper (for example, very fine grit for laminate), and if necessary, apply a primer or adhesion promoter.
I’m also curious about how you use the furniture. Is it heavily used as a TV cabinet, or more as a sideboard with little wear?
Another often overlooked point is that the paint should be UV-resistant if the furniture stands near a window; otherwise, the color fastness will deteriorate over time.
Maybe you could provide some more specific details so that more tailored product recommendations can be given.
benonon schrieb:
Polyurethane varnishes (PU varnishes) are extremely resistant to scratches, chemicals, and moisture.That sums up the key point very well. Additionally, I would like to add that polyurethane-based coatings are mostly offered in 2K versions (two-component), which contributes to the final hardness and durability.
For use on IKEA Besta furniture, I would also recommend the following process:
- Clean the melamine-coated surface with an appropriate degreaser
- Lightly sand with a very fine grit (at least 400), to slightly roughen the smooth surface
- Apply a special adhesion primer suitable for foil and coated surfaces
- Apply the 2K PU varnish in thin layers, preferably using a quality spray gun or a fine paint roller
This procedure ensures optimal adhesion between the existing furniture surface and the new varnish layer.
Alternatively, water-based 2K acrylic varnishes are more environmentally friendly but usually do not offer the same scratch resistance as PU varnishes.
It should also be noted: The curing time of the varnishes must allow the furniture enough time to fully harden, as surfaces that are loaded too early often show damage.
bumere schrieb:
Which paint holds up best here – even with frequent use and heavy wear?This really hits the mark for us; we had the same problem last year with our Besta cabinets in the kitchen.
My experience: Anything applied too thickly quickly looks unprofessional and is quite prone to cracking. It’s better to apply several thin coats, sanding between each one.
Back then, we tried an acrylic paint – it was pretty good for everyday use, with hardly any odor and dried fairly quickly. But for the living room, where there are larger surfaces, I’ll probably use a good polyurethane (PU) paint next time, simply because the result looks much more durable.
One more tip: If you sand the paint layers very lightly in between, you’ll get a super smooth finish, almost like in a furniture showroom. So prepare carefully, don’t just start painting.
Good luck!
