ᐅ Which paints and finishes work well with Ikea BESTA furniture?
Created on: 18 Apr 2024 08:43
logasu
logasu
18 Apr 2024 08:43
Good morning everyone,
I am planning to personalize my Ikea Besta furniture by painting or applying colors. My question to the community is: Which paints and coatings work well on Ikea Besta furniture? Specifically, I am interested in:
- Which types of paint (e.g., acrylic paints, paint pens, spray cans) are best suited for the surface to achieve a durable and visually appealing finish?
- What should I consider beforehand, for example regarding the surface material (plastic, laminate?), to ensure good adhesion of the paint?
- Are there color tones that particularly complement the most common Besta colors (white, black-brown, oak)?
- What surface finishes are possible (matte, glossy, satin) and how do they affect the appearance and maintenance?
I want to make this as durable and low-maintenance as possible. Maybe someone already has experience or tips on preparation, the painting process itself, and the choice of paint and coatings.
Thanks in advance for your insights!
Filippo
18 Apr 2024 09:21
Hello logasu,
to answer your questions as thoroughly as possible, here is my detailed approach:
Most BESTA furniture surfaces are melamine-coated or covered with a foil finish. These surfaces are quite resistant due to their smooth, often lacquer-like texture, but they are also difficult to repaint because paints tend to adhere poorly.
Therefore, preparation is crucial:
- Lightly sand the surface to improve paint adhesion. Be sure to use very fine sandpaper (grit 220 to 320) to avoid penetrating the coating.
- A special primer designed for smooth surfaces is highly recommended to enhance durability.
Regarding the paint, water-based acrylic paints are usually well suited because they have low odor, provide good coverage, and are durable. Alternatively, 2K paints (two-component) also offer a very robust finish but are more complex to apply.
For color selection:
- White is, of course, classic and always works, easily coordinating with almost any color scheme.
- Dark brown or black surfaces work especially well with matte or satin finishes, as these emphasize a sophisticated look and reduce visible fingerprints.
- Oak surfaces pair nicely with warm tones (terracotta, olive green) or contrasting colors like dark blue or anthracite.
Surface texture:
- Matte finishes hide minor imperfections and scratches better and look more modern.
- High gloss looks elegant but requires careful preparation and is more sensitive to scratches.
- Satin finishes are generally easier to maintain and offer a pleasant appearance.
Finally, when painting, apply very thin coats and lightly sand between each layer. This helps prevent unsightly drips and ensures a long-lasting finish.
I hope this provides you with a good starting point. For more precise advice, details about the type of BESTA fronts (e.g., glass, melamine, foil) would be helpful.
neoren
18 Apr 2024 09:59
For most BESTA furniture, I would recommend acrylic lacquer. First, lightly sand the surface and apply an adhesion primer. Neutral colors such as gray, off-white, or pastel green work well and create a modern look.
logasu
18 Apr 2024 11:17
Thank you Filippo and neoren for the initial tips, especially the advice regarding primer and the fine sanding work.
To ask more specifically: My BESTA furniture all has a glossy white foil finish – so it's not a painted wood surface. I assume this means the surface is relatively smooth and silicone-hard, correct?
In this case, would you recommend using paint pens or spray cans to ensure the paint adheres properly? And what are your thoughts on using PU varnishes for this smooth foil surface?
I'm also interested in the topic of clear coat as a final layer: Is a thin layer sufficient to protect the paint, or is it more optional?
Looking forward to your opinions, as I want to enjoy the surface for as long as possible.
GALEO4
18 Apr 2024 13:02
logasu schrieb:
My BESTA furniture all has a glossy white foil finish – so it’s not a painted wood surface. Therefore, I assume the surface is relatively smooth and silicone-hard, right?
Exactly, these surfaces are a real challenge for any type of paint. And here I see the problem:
Standard paints often only adhere for a short time on these foils, with glossy foils making it even more difficult.
If you really want the finish to last permanently, in my opinion two things are crucial:
- Extremely thorough cleaning followed by light sanding (definitely not too aggressive, otherwise you’ll damage the foil)
- Primer specifically designed for plastics and foils
Spray cans? They can work, but often result in uneven coverage, especially on glossy surfaces. Paint pens are too small-scale for furniture fronts.
PU paints (polyurethane) are very durable and ideally recommended as the final topcoat, as they protect the color paint very well against scratches and wear.
logasu schrieb:
I’m also interested in the subject of clear coat as a final layer: Is a thin coat enough to protect the paint, or is it more optional?
A clear coat is not mandatory, but highly recommended if you want your paint to last a long time. For glossy surfaces, choose a clear coat without a matte effect.
My conclusion: You need special products and a lot of patience during preparation. Ordinary household paints can be ruled out if you really want something long-lasting.
pikin
18 Apr 2024 15:46
In addition to the previous answers:
The best paints for IKEA BESTA furniture with foil surfaces are acrylic paints with adhesion primer, as these adhere well to plastic foils.
Important points are:
- Light sanding with fine sandpaper (grit 240-320)
- Cleaning with alcohol or silicone remover before painting
- Several thin layers of paint instead of one thick layer
- A clear coat as a protective layer increases abrasion resistance and makes cleaning easier
Spray cans offer quick application but are harder to control in terms of paint coverage. PU (polyurethane) paints are durable but more demanding to apply and require good ventilation.
Colors that complement white fronts well include pastel shades, neutral grays, and warm earth tones.
Matte paints are more forgiving of small surface imperfections, while glossy paints reveal them more.
For a long-lasting solution, using an adhesion primer is essential.
