ᐅ Which mounting screws are suitable for IKEA Metod wall cabinets?
Created on: 13 Dec 2023 09:17
raglaHello everyone,
I am currently planning to install several IKEA Metod wall cabinets at my home and want to use the appropriate mounting screws. Since some of the cabinets will be quite heavy and should be securely fixed for the long term, I want to make sure I choose the best screws.
Therefore, my question is: Which mounting screws are suitable for IKEA Metod wall cabinets, especially when dealing with different wall types such as concrete or drywall/plasterboard? What should I consider regarding the length, material, and diameter of the screws?
I am also interested in whether there are specific screws that IKEA recommends, or if there are better external alternatives. If anyone has experience with installing these cabinets, I would appreciate any advice—particularly regarding the weight limits to keep in mind!
Best regards and thanks in advance!
ragla schrieb:
Which mounting screws are suitable for IKEA Metod wall cabinets, especially when dealing with different wall types like concrete or drywall?Hey ragla,
great that you’re thinking about this! I personally hung my Metod cabinets on a concrete wall using standard anchors with matching metal screws. For concrete, I always use screws with at least 6 mm (1/4 inch) diameter and about 60 mm (2 1/2 inch) length, depending on the anchor size. Material: stainless steel is always reliable and rust-free.
For drywall, it’s tricky: regular anchors are not enough because they won’t hold the cabinet. I would recommend special hollow wall anchors—preferably metal toggle bolts or heavy-duty anchors. The screw length should be adjusted accordingly.
In short:
- Concrete: 6 mm (1/4 inch) stainless steel screws + suitable anchors, length around 60 mm (2 1/2 inch)
- Drywall: metal toggle bolts + 6–8 mm (1/4–5/16 inch) screws, length depending on the anchor
IKEA unfortunately doesn’t provide top tips here; the screws included are usually short and best suited for light cabinets or when you have an additional support board.
Good luck with your mounting!
Cheers, mauka
Matthewt4813 Dec 2023 12:47Hello ragla,
I would like to add some basic information, partly because your question specifically asks about the appropriate screws for Metod wall cabinets and different wall types.
First: The Metod cabinets are designed for wall mounting, which means that the load-bearing capacity of the wall and the screws/anchors used is crucial.
My recommendations:
- For concrete walls: Use heavy-duty anchors (e.g., nylon or metal expansion anchors) with screws 6 to 8 mm in diameter, at least 60 to 80 mm (2.4 to 3.1 inches) long, depending on the cabinet height and the load.
- For drywall (plasterboard) walls: Without additional reinforcement (e.g., wooden battens or a sturdy wall panel), wall cabinets are risky. If you don’t have reinforcement, be sure to use special hollow wall anchors or metal toggle bolts that securely distribute the weight within the wall. Screw length around 50 to 70 mm (2 to 2.8 inches), depending on the size of the anchors.
When choosing screws, you should also:
- Prefer stainless steel, as it is rust-resistant
- Look for square (Robertson) or Torx drive to prevent slipping when screwing in
The mounting hardware provided by IKEA is usually more of an emergency kit and is not designed for heavy loads. So, if you are mounting more than just light objects, it is worth using high-quality screws and anchors.
I hope this brings some more clarity to your considerations.
My recommendations:
Matthewt48 schrieb:
For concrete walls: Use heavy-duty anchors (e.g., nylon or metal expansion anchors) with screws 6 to 8 mm in diameter, at least 60 to 80 mm (2.4 to 3.1 inches) longThis is a very important point because when installing IKEA Metod wall cabinets, you must pay close attention to the maximum allowed load of the anchors and screws. An undersized anchor will not support the weight—especially when the cabinets are fully loaded.
Additionally, it is important to ensure the screws securely hold the cabinet’s mounting brackets. Depending on whether you use a visible or concealed fixing, a specific screw head type (e.g., countersunk or pan head) is often recommended.
For drywall (plasterboard), I strongly recommend, if possible, attaching a wooden support strip behind the drywall before installation. This distributes the weight much better than any hollow wall anchor. It saves you a lot of hassle and increases safety.
In brief:
- Use high-quality heavy-duty anchors
- Screws 6–8 mm in diameter, length dependent on the anchor
- Prefer stainless steel materials
- For drywall: Reinforce behind the wall or use specially tested hollow wall anchors
This way, you’ll be on the safe side and the cabinets will hold securely without any issues.
ragla schrieb:
Which mounting screws are suitable for IKEA Metod wall cabinets, especially when dealing with different wall types like concrete or drywall?I understand that this question is really important to you, especially considering how frustrating an insecure installation can be. I had a similar situation last year when I used a combination of those “cheap” anchors and screws that IKEA provided on a drywall—I’m afraid it didn’t last long. One cabinet eventually came loose from the wall, fortunately without major damage, but I was quite upset and uncertain.
Since then, I insist on using:
- For concrete walls: sleeve anchors or metal expansion anchors (avoid cheap plastic versions)
- Screws with at least a 6 mm diameter, length depending on the anchor
- For drywall, if reinforcement is not possible: metal toggle bolts (never purely plastic) and longer screws so the clamping mechanism works properly
What also helped me was measuring the actual expected weight (fully loaded Metod cabinets can easily reach 20–30 kg (44–66 lbs) or more per cabinet) and accordingly reinforcing the anchors or planning multiple fixing points.
If you’re still uncertain, don’t stress too much—better to plan thoroughly in advance than to be unpleasantly surprised later.
All the best and good luck!
