ᐅ What fastening options are suitable for additional inserts in IKEA Besta units?
Created on: 22 Apr 2019 10:07
V
VITONAU56
Hello everyone, I want to add some extra inserts to my IKEA Besta shelving unit to create a more customized layout. My question is: What are the best fastening options to securely and permanently attach additional shelves or inserts within a Besta system? It’s important to me that the solution is stable, preferably reversible or can be done without causing significant damage to the furniture, and that it doesn’t affect the appearance. I’ve considered small screws, brackets, or special fittings, but I’m not sure what the best approach is. Are there any suitable IKEA accessories, DIY tips, or specific components you would recommend? Thanks in advance for your advice!
V
VITONAU56
23 Apr 2019 09:16
Peone schrieb:
It is important to ensure that the rear stability is not compromised, especially if the insert is expected to bear weight. Screws in the side panels should always be used sparingly to avoid damaging the material.
Thank you, that is an important point I had not really considered. Are the standard drill holes in Besta also suitable for other types of inserts later on, or should they ideally be used as intended? I ask because I am planning some inserts that differ slightly in size.
V
vinicius44
23 Apr 2019 10:47
The standard holes are mainly designed for the original shelves and accessories. If your inserts differ in size, it is advisable to customize the fittings accordingly. For example:
- Drill your own holes in inconspicuous areas.
- Use brackets that can also be secured with screws to the bottom or back panel.
- Always ensure not to damage any load-bearing elements.
If you want to maintain the appearance, hidden fittings can be used that remain invisible when the shelf is closed.
ixlu1
24 Apr 2019 08:02
VITONAU56 schrieb:
Are the standard drill holes in Besta also suitable for other types of inserts afterwards, or should they preferably be used as originally intended?
The original drill holes are a great reference point, but especially for custom solutions, you can be a bit more flexible! For example, I’ve mounted small perforated plates or rails on the sides to slide inserts in and out. Experiment with it – it’s worth it and a lot of fun!
kla65
24 Apr 2019 11:23
If stability is to be ensured, angle brackets or small shelf rails are worthwhile. Adhesives are only recommended for light-duty applications. Always pre-drill before screwing into the pre-drilled holes.
