ᐅ What are the best mounting methods for IKEA Brimnes?
Created on: 26 Jul 2024 19:43
DAANPEO
DAANPEO
26 Jul 2024 19:43
I am currently looking into the installation and securing of IKEA Brimnes furniture, especially dressers and beds. Since stability and long-term safety are very important to me, I would like to know: What fastening methods are best suited to securely attach Brimnes furniture to the wall or to assemble it in a stable manner?
I am particularly interested in:
- Comparisons of different wall fasteners (e.g., types of anchors, wall plugs)
- Whether additional brackets or special reinforcements on the furniture are advisable
- Tips for installation on various wall types (e.g., concrete, drywall, brick)
- Experiences regarding stability under load
I look forward to detailed experiences and recommendations. Thank you in advance!
fredle
27 Jul 2024 07:31
Hello DAANPEO,
First of all, an important note: The stability of Brimnes furniture depends heavily on proper wall mounting, especially because the furniture is relatively light and often built quite tall.
Regarding your questions:
- Types of anchors: For concrete walls, I recommend heavy-duty anchors or metal anchors that ensure a secure hold. For drywall (plasterboard), use hollow wall anchors (such as toggle bolts or metal spring anchors) to prevent pull-out.
- Corner brackets: Installing additional corner brackets between individual furniture parts or to the wall can significantly improve stability. Many users underestimate that the furniture itself has limited load-bearing capacity.
- Installation on different wall types: Choosing the right anchor is essential. Never use standard universal anchors if the wall is soft (drywall or insulation). For brick walls, you should also use high-quality anchors.
- Stability: Brimnes models are stable for normal use, but if you load the furniture heavily or have small children at home, you should not skip wall anchoring systems.
In conclusion: Always mark with a spirit level and drilling guide first, then attach the fasteners step by step. A common mistake is attaching the furniture only to the frame instead of securely anchoring it to the wall.
I hope this helps you with your decision!
Josefane
27 Jul 2024 19:12
I would like to critically revisit this point. Brimnes furniture is produced cost-effectively and often uses medium-density fiberboard (MDF). As a result, IKEA’s furniture construction comes with certain limitations regarding load capacity.
In my view, it is important not only to focus on the wall mounting but also to consider the weight and the type of use. An adapter for additional reinforcement or strengthening of the furniture itself is essential, especially if drawers are used regularly or heavy items are stored.
DAANPEO schrieb:
Experiences with stability under load
This is, in my opinion, the crucial point that is often underestimated. For safe use in rooms with playing children or frequent opening and closing, not only the wall anchors matter but also optimized furniture reinforcement. It would be great if there were specific product recommendations or user experiences shared on this.
Domau0
28 Jul 2024 08:27
DAANPEO schrieb:
Which fastening methods are best suited to securely fix Brimnes furniture to the wall or to assemble it stably?
Very good question, and I’m happy to go into some detail:
1. Wall fastening:
- For solid walls like concrete or load-bearing brick, metal expansion anchors (e.g., Fischer SX or UX) are the best choice. These expand inside the drilled hole and provide strong holding power.
- For drywall or plasterboard walls, I never use plastic anchors alone. Instead, metal toggle bolts or all-purpose metal anchors that spread behind the wall are used to prevent tearing out of the board.
2. Furniture reinforcement:
- Brimnes furniture is often made from particleboard panels. Additional metal corner brackets on the back of the furniture strengthen the edge connections and reduce wobbling over time.
- Also, retightening the screws after a few weeks of use is crucial.
3. Assembly process:
- Before drilling, make sure everything is perfectly leveled and check the exact position for the anchors.
- Never drill holes that are too large so the anchor doesn’t lose grip.
- When fastening the furniture to the wall, use the included safety kits—typically, IKEA supplies wall anchors matched to the furniture.
4. Loads and usage:
- For heavily loaded dressers (many drawers filled with clothes or books), I recommend installing multiple fastening points per piece of furniture.
- For beds like Brimnes, sometimes an additional fix for the slatted frame is necessary.
5. Safety:
- Especially with small children, a secure wall fastening is essential to prevent tipping hazards.
If you want, I can also provide a list of recommended anchors and bracket types. Otherwise: Always adapt to the wall’s construction and don’t skimp on fastening hardware.
