ᐅ What modular storage solutions can be created using IKEA Besta?
Created on: 16 Aug 2024 09:37
Bran39
Bran39
16 Aug 2024 09:37
Hello everyone, I’d like to start a discussion on the topic of “What modular storage solutions can be created using IKEA Besta?” I’m particularly interested in how the Besta system can be combined to flexibly meet different storage needs—whether for the living room, home office, or even custom projects like media shelves or storage for craft supplies. I’ve already seen that various fronts, shelves, and interior fittings can be used, but I’m still lacking a clear overview of which modular options specifically offer storage and organization solutions. Who has experience with this—perhaps even with special extensions that are not directly from IKEA? I look forward to concrete tips and examples, including any insights on material properties or load capacities. Thanks!
Dustin
16 Aug 2024 10:12
With Besta, you can easily assemble shelves and cabinets in various sizes. Use boxes and drawers for small storage, and open shelves for bulky items. The modules can be easily stacked or arranged side by side using connectors.
Nabla64
16 Aug 2024 12:55
First, a brief overview: Besta is very versatile due to its modular design, especially because you can combine elements in width, height, and depth. For modular storage solutions, I recommend the following approach:
- Step 1: Plan your storage needs – think about what you want to store (e.g., books, clothing, electronics, craft materials).
- Step 2: Choose the appropriate Besta units – the basic frames come in several sizes, such as 60x40 cm (24x16 inches) or 120x40 cm (47x16 inches).
- Step 3: Use interior fittings deliberately – IKEA offers drawers, doors, shelves, and baskets that you can combine flexibly.
- Step 4: Fronts and materials – here you can choose between doors with glass, wood finishes, or open storage. This allows for both concealment and display space.
Avoid common mistakes: Users often tend to choose too many open shelves, which can look messy. It is better to use multiple closed drawers and boxes to prevent dust and create a visually calm appearance.
Summary: With Besta modular, you can create almost any kind of storage, from sideboard solutions to media furniture or a small shelf for the hallway. Assembly is straightforward, and you can add or modify components later.
Domau0
17 Aug 2024 08:44
I’d like to go into a bit more detail here, as the possibilities with IKEA Besta are actually quite extensive, especially when planning modular storage.
First, about the construction: The basic Besta units come in different widths (approximately 60, 120, 180 cm (24, 47, 71 inches)) and depths (mostly 40 cm (16 inches), partly 20 cm (8 inches) for narrower solutions). The modules can be combined both horizontally and vertically, resulting in a wide variety of storage options. It is important to pay attention to the maximum load capacity of the shelves, which typically support up to 25 kg (55 lbs) evenly distributed.
For the interior configuration, there are the following core options:
- Drawers of various heights, ideal for small items, clothing, or paperwork
- Doors with or without glass, depending on taste and purpose
- Open shelves, suitable for books, decorations, or multimedia
Additionally, there are internal pull-outs and organizers available that make the storage very functional. For larger areas, you can place multiple shelves to optimize space usage. For special tasks, such as a DIY workstation or sewing area, I have built my own partitions, often supported by third-party inserts that fit precisely.
Regarding materials: The modules are made of melamine-coated particleboard, which makes them sturdy and easy to maintain but also limits their durability in moist environments. For locations like basements or bathrooms, you should consider special alternatives (for example, lacquered fronts or additional protective measures).
Finally, I recommend paying attention to the overall stability of the modular setup. If you use several tall units, it is advisable to plan wall mounting to increase safety. It also makes sense to choose units with casters for mobile applications.
If you like, I can help you create a module plan for your specific room – but for that, I would need some measurements and information about the types of items you want to store.
Bran39
17 Aug 2024 11:03
Nabla64 schrieb:
Avoid common mistakes: Users often tend to choose too many open compartments, which can look cluttered. It’s better to use several closed drawers and boxes to prevent dust and create visual calm.
That’s a really helpful tip, thank you! I’m actually considering using the system mainly for my home office and also the living room. It should offer enough space for folders and literature on one hand, and on the other hand, easy access to multimedia devices or cable management.
Domau0 schrieb:
If you want, I’d be happy to help you create a modular plan for your specific room – but I would need some measurements and information about the types of items you want to store.
I’d like to take you up on that. My room is about 4 meters (13 feet) wide and 3 meters (10 feet) deep, with a window on the long side, and a ceiling height of 2.50 meters (8 feet 2 inches). I need flexible storage for:
- folders and files
- smaller technical devices (e.g. router, printer)
- craft supplies and tools
- also some books and of course space for decoration
The goal is a combination of organization and a certain design freedom, especially avoiding a furniture piece that feels too heavy and overwhelms the room. Thanks in advance for your further advice!
