ᐅ Which materials work well with the Pax system for DIY renovations?
Created on: 4 May 2024 09:37
Kugunnar
I would like to start a thread for discussion about the question: Which materials work well with the Pax system for DIY modifications? I am particularly interested in which materials are best suited for making adjustments or additions to the modular Pax wardrobes from IKEA, without compromising appearance, stability, or functionality. It would also be helpful if you have experience with which materials bond well with the typical Pax finishes (melamine, wood veneer, painted surfaces) and which should be avoided. I am referring to both structural elements and decorative or practical enhancements. Thanks in advance for your informed contributions!
Blavin
5 May 2024 08:14
sifope schrieb:
In my opinion, one should carefully consider which material to use for each function.
I agree with that. Materials should always be chosen according to their intended function. Another often overlooked aspect is the compatibility of surface finishes. For example, melamine-coated fronts and full-surface melamine panels can be sensitive to aggressive adhesives or screw connections, which may cause chipping.
Therefore, I recommend using only specialized wood glues or assembly adhesives designed for wood-based materials when bonding, and pre-drilling the designated hole with a drill to avoid wood splitting when screwing. For surface treatments, polyurethane (PU) coatings or special waxes are also suitable to preserve the material’s appearance.
kieran
5 May 2024 09:43
One aspect I would like to add is compatibility with assembly. Some materials are easier to work with using basic hand tools like jigsaws and cordless drills than others. For example, MDF is easy to mill and sand, whereas chipboard tends to chip when drilling.
If you want to minimize effort, you should also ensure that the material thickness is compatible with the system. Pax profiles are often designed for 16 mm (5/8 inch) – significantly different thicknesses require adjustments to the joints or special fasteners.
In summary: choose based on function, workability, and compatibility.
SETHBLA
6 May 2024 11:07
For simple additional elements like covers or cladding, I usually use 8 mm (5/16 inch) MDF. It is lightweight, affordable, and durable. For load-bearing parts, definitely use multiplex plywood with 15 mm (5/8 inch) thickness or more.
Ankeli
6 May 2024 13:12
Aluminum profiles are excellent for drawer slides and joints because they are sturdy and space-saving. Wood-based materials are suitable when appearance is a priority.
Kugunnar
6 May 2024 18:45
Thank you for the comprehensive and well-structured contributions. Here is my summary: plywood is considered the standard material for load-bearing renovations, MDF for fronts and decoration, and aluminum for profiles and reinforcements. Screen-printed panels could also be a practical alternative in moist conditions. Careful workmanship and proper surface protection are essential. I am also interested in how you handle the appearance when combining different materials—what has proven effective in creating a uniform look despite the DIY character?
