Hello everyone, I am currently looking into purchasing an Ikea Brimnes wardrobe and would like to learn more about the materials used in its construction. It would be helpful to know the main materials for the carcass, doors, and back panels, whether they are mostly particleboard, MDF, or possibly some solid wood areas, and what type of surface finishes are applied (e.g., melamine, foil, lacquer). Additionally, I am interested in whether any special materials are used for the hinges, handles, or mounting hardware that could affect durability. Does anyone have detailed knowledge about this or access to official product information that includes these details? Thanks in advance!
The Ikea Brimnes wardrobe is mainly made from particleboard (also known as wood-based panel), which is used for both the frame and the doors. These particleboards are often coated with a melamine foil that provides a smooth, durable surface and protects the furniture from scratches. The back panels are usually made from thinner hardboard (MDF or HDF), which is common to reduce weight and cost, as these parts are not load-bearing.
The door fronts are not made of solid wood but are also constructed from coated wood-based panels. A key advantage of this construction method is its good value for money combined with relatively high stability. The hinges are typically made of galvanized metal and ensure durable operation over time. Handles are usually made of plastic or powder-coated metal, keeping the design deliberately simple while remaining durable.
pikin schrieb:
The Ikea Brimnes wardrobe is mainly made from particleboard (also known as chipboard)Thank you for the detailed description, it helps me a lot! I have had the Brimnes wardrobe myself for a few months and sometimes felt a bit uncertain about whether the materials will last in the long term. Your information confirms my observation that with careful use it can indeed be durable.
It would be interesting to know how sensitive the melamine coating is to moisture, as that sometimes worries me. Has anyone had experience with maintenance or long-term use, especially in humid rooms or under heavy wear? I would really appreciate gathering such practical insights alongside the basic facts.
MAVERICKKA18 Jul 2016 08:43TuLevi schrieb:
It would be interesting to know how sensitive the melamine coating is to moistureThis is a very valid question, as melamine coatings are resistant to scratches and abrasion but are not completely waterproof. Long-term exposure to moisture can cause particle boards to swell and may lead to deformation.
pikin schrieb:
The back panels are usually made from thinner hardboard (MDF or HDF)An important point here: MDF and HDF also tend to swell when exposed to moisture, which can affect stability, especially in the thinner back panels.
Therefore, I would recommend not using the Brimnes wardrobe in very humid rooms and ensuring careful maintenance with prompt removal of any moisture. Additionally, such furniture is more affordable than solid wood but does not offer the same level of durability against moisture or strong mechanical stress.
To complement the previous posts, I can add that Ikea generally uses industrially manufactured wood-based panels such as particleboard with melamine or foil coating as standard. This keeps costs low while providing a neat appearance.
In the case of the Brimnes wardrobe, attention should also be paid to the edge sealing of the particleboard, as this is an important factor in protecting the furniture from moisture. Ikea usually finishes the edges with ABS edging or a special foil that offers some protection. However, the material is still sensitive if water is constantly applied or allowed to stand.
The hinges are designed to withstand many opening cycles, which is a good feature for an affordable piece of furniture. The doors are held in place by metal fasteners securely anchored in the carcass. The handles typically combine plastic with metal, which also makes the design simpler and easier to maintain.
