ᐅ Which materials are suitable for repairing IKEA Hemnes furniture?
Created on: 3 Jul 2024 09:27
LUCORYHello everyone,
I am currently looking into the best materials for repairing furniture from the IKEA Hemnes series. Often, you see damage on such furniture at corners, scratches, or small holes in the wood or MDF components. Since Hemnes is mainly made from solid pine wood parts and partly veneered panels, I’m wondering which materials can be used to make repairs that are both durable and visually matching.
Are wood- or MDF-based fillers better? Are simple wood glues or cyanoacrylate adhesives sufficient? Are there any filler materials or repair kits specifically recommended for Hemnes? I am also interested in which surface treatments (varnish, stain, or oil) work best for repairs to achieve a smooth and visually consistent finish.
I look forward to your experiences and recommendations—especially if you have practical tips or advice on common mistakes.
your question is very well formulated and shows that you are already familiar with the materials. Basically, for the Hemnes series, which is made of solid pine wood, wood glue is the first choice for bonding or repairing cracks. For small repairs, such as minor dents or scratches, you can use wood filler based on wood, which can be sanded and refinished easily.
It is important to treat the surface accordingly afterward. IKEA often uses pine wood for Hemnes with a light, slightly satin finish, which is usually protected with varnish or a wood stain. Water-based varnishes work very well here because they have less odor and hardly discolor after drying.
If you plan larger repairs: a two-component wood filler can be more durable than standard fillers. But if all this sounds too technical, often a good wood glue with some follow-up work is sufficient.
I’m happy to provide tips on substrates or sanding techniques if you like.
I think it makes sense not to dismiss “wood filler” as a repair material without asking which type exactly and what ingredients it contains. For pine wood, it is important that the filler does not shrink or crack too much, otherwise new damage can occur.
That is basically true, but do you have experience with whether IKEA Hemnes can really be color-matched with standard wood filler without the filler showing through? I actually doubt that – so for me, the option of a color-adjustable wood repair kit that better matches pine tones would be interesting.
Additionally, I wonder whether for most damages a natural resin-based or even rubber-based wood putty would be better, as these remain more flexible. In my opinion, this is an important factor when repairing furniture that is not only statically loaded but also used constantly, for example in households with children.
Jukin schrieb:
For repairs, such as small dents or gouges, you can use wood-based filler, which can be sanded well and treated afterwards.
Thank you for the responses so far. I find Josefane’s question very interesting. Until now, I had mostly considered traditional wood filler, but the points about flexibility and shrinkage make sense.
Regarding surface treatment: Has anyone had specific experience with water-based varnishes on Hemnes pine wood, especially after repairs? I assume compatibility is particularly important with touch-ups to avoid unsightly edges or color differences.
Also, I’m curious how you repair small chipped edges without causing unevenness. Do you use small wood strips or filler material? Thanks for your opinions!
Hello, LUCORY,
for chipped edges on Hemnes furniture, I have had good experiences using narrow pine wood strips that can be shaped by sanding. You can fix these in place with wood glue and later color-match them.
Regarding the surface finish, I recommend water-based varnishes or specialized furniture oils that bond well with the original finish and have minimal yellowing. Filling in with two-component (2K) wood filler works well if the surface is finely sanded afterward.
I would also make sure that the sandpaper is not too coarse (at least 180-220 grit) to keep the surface smooth and prevent any imperfections from showing through after painting. For small areas, wood repair markers or wax fillers are also suitable if you want a quick and clean fix.
