ᐅ Which materials are suitable for repainting IKEA Metod cabinet fronts?
Created on: 25 Nov 2020 09:23
raul51
raul51
25 Nov 2020 09:23
Hello everyone, I am planning to repaint my IKEA Metod kitchen fronts because the original fronts have become a bit too plain after several years of use. My question is: which materials are best suited for repainting IKEA Metod fronts to achieve a durable result? I am particularly interested in recommendations regarding paint types (e.g., acrylic paint, alkyd paint, chalk paint), suitable pretreatments such as primers or undercoats, and whether certain products should be avoided to prevent peeling or scratches. I look forward to your experiences and tips, including advice on the proper work process and surface preparation.
U
usbla
25 Nov 2020 09:45
Regarding the question of which materials are best for repainting IKEA Metod fronts, here is a brief overview of the material structure: Metod fronts are usually made of medium-density fiberboard (MDF) with a foil or lacquer coating. For a durable repainting, surface preparation is crucial. Removing the old coating or at least carefully sanding it is essential. For the paint itself, I recommend water-based acrylic polyurethane (PU) paints, as they provide good adhesion and high scratch resistance. Special primers for foil fronts improve the bond between the old and new paint. Synthetic resin paints are also suitable but require longer drying times and may potentially cause the foil to lift. Chalk paints tend to be too porous and do not offer the durability needed for kitchen fronts. Finally, I recommend a matte or satin-matte PU lacquer sealant as a protective topcoat.
blapau
25 Nov 2020 10:17
usbla schrieb:
For the paint itself, I recommend water-based acrylic paints with a polyurethane (PU) base, as they offer good adhesion and high scratch resistance.
This matches my experience as well. It is also important to use a primer specifically designed for smooth plastic or foil surfaces to prevent the paint from chipping later. Instead of sanding, a bonding agent can also be used. With cheap paints, the attractive appearance often does not last long.
Saramar
25 Nov 2020 11:02
In short and clear terms: Thoroughly sand IKEA Metod cabinet fronts before painting. Then use water-based acrylic paint. Do not use chalk paint, as it doesn’t hold up well enough.
PLOMA
25 Nov 2020 12:47
I would like to go into more detail about the preparation, as it significantly affects the durability of the new coating. Metod fronts usually have a foil coating that is very smooth and abrasion-resistant. Simply sanding them is rarely enough, as the foil acts as a barrier. Therefore, the following procedure is recommended:
- Thoroughly clean the work surface and fronts, removing grease and dirt
- Sand with very fine sandpaper (grit 240–320) to roughen the surface and the foil without sanding through it
- Apply a suitable adhesion promoter (adhesion primer for plastic foils)
- After the primer has dried: apply the first coat with a water-based, PU-reinforced acrylic paint
- Sand lightly after drying (using fine sanding fleece or sandpaper)
- Apply a second coat for sealing, depending on the desired level of gloss
Questions for raul51: How heavily used are the fronts (wear and tear) and what kind of color finish are you aiming for? That would help me provide more precise recommendations.
GiRoyce
25 Nov 2020 13:05
As an addition: there are also fronts with melamine coating that are treated in a similar way. In this case, it is even more important to carefully sand the surface by hand with fine grit and apply a primer. You can also work with several thin layers of paint to create a smooth and durable finish. Patience during drying and thorough sanding between coats are essential for a professional result. Anyone painting for the first time should also consider using appropriate respiratory masks and ensuring good ventilation.
