ᐅ Which materials are suitable for building a DIY kitchen backsplash with IKEA Metod cabinets?
Created on: 17 May 2021 18:23
Ronsi6
I am currently planning to install my kitchen using the IKEA Metod system and would like to add a custom backsplash. I am wondering which materials are best suited for a DIY kitchen backsplash that is durable, easy to maintain, and heat-resistant, without the effort or cost becoming excessive. It is also important to me that the backsplash is easy to install and not too heavy, as I will be mounting it myself.
Does anyone have experience or recommendations on whether certain plastic panels, HPL (high-pressure laminate), tiles, glass, wood-based panels, or other materials are better? Are there practical combinations or special installation methods that work particularly well with the Metod system?
I would really appreciate any tips or advice!
Hello Ronsi6,
I’m happy to give you a more detailed answer. For a DIY kitchen backsplash with the IKEA Metod system, you should consider the following:
- Material properties: heat resistance, moisture resistance, ease of maintenance, and weight
- Workability: How easily can you cut and install the material yourself? Are there pre-cut options available?
- Appearance: Should the backsplash look modern, rustic, or rather neutral?
Recommendations:
1. HPL (High Pressure Laminate): Very suitable because it is durable, waterproof, heat resistant up to about 180°C (356°F), and available in many designs. Cutting can be done with a jigsaw or a circular saw.
2. Glass: Excellent for hygiene and easy to clean, heat resistant, and protects the wall well. However, it requires professional cutting since it is difficult to work with using regular tools.
3. Aluminum composite panels: Lightweight and impermeable, also corrosion resistant. Installation is straightforward.
4. Moisture-resistant engineered wood products (OSB, MDF) with appropriate sealants: The most affordable option, but less durable and heat resistant.
5. Tiles: The classic choice, very robust and heat resistant, but installation is labor-intensive and heavy.
If you are not very experienced with DIY, I recommend HPL or aluminum composite panels, as they are easier to handle. For glass, professional cutting is essential.
I hope this helps!
Recommendations:
I hope this helps!
Thanks in advance for the initial recommendations. I’m wondering how the installation might work in practice, especially when using HPL or aluminum composite panels. Can they simply be glued to the existing wall with construction adhesive, or are special substructures required? And what about the weight—how feasible is it for a DIY installation?
I have particular concerns about glass, as I have little experience and the cost is likely to rise quickly depending on thickness and size. The risk of damage during transport or installation is probably higher as well, right?
Ronsi6 schrieb:
Can you simply glue them to the existing wall using mounting adhesive, or are special substructures necessary?For HPL and aluminum composite panels, direct bonding with high-quality mounting adhesive is possible as long as the wall is dry and level. Substructures are generally only required for very uneven surfaces or with heavy materials.
Ronsi6 schrieb:
And what about the weight for installing them by yourself?HPL is relatively lightweight, usually between 6 and 10 kg/m² (1.2 to 2.1 lbs/ft²). Aluminum composite panels weigh even less, around 3 to 5 kg/m² (0.6 to 1.0 lbs/ft²), which is easy to handle alone. Glass, on the other hand, can become significantly heavier depending on thickness and size, making installation more challenging.
Super interesting topic! I’m using an HPL back panel myself and can only say: mounting it with adhesive was easy and it holds really well! It’s worth using a spirit level and spacers as helpful tools.
In addition, HPL is very easy to clean, with hardly any signs of wear after more than a year.
And yes, glass looks sleek, but it’s also fragile. If it breaks, you’ll have real trouble. 🙂
I built a backsplash for my Metod kitchen using laminate wood-based panels treated with waterproof lacquer. Considering the price, the result is really great! Of course, it’s not as heat-resistant as glass or high-pressure laminate (HPL), but it’s perfectly sufficient for typical kitchen areas.
Installation is simple with screws placed in the joint or adhesive pads. Great for DIY, no professional needed!
