ᐅ Which materials are suitable for building a DIY kitchen backsplash with IKEA Metod cabinets?
Created on: 17 May 2021 18:23
Ronsi6
Ronsi6
17 May 2021 18:23
I am currently planning to install my kitchen using the IKEA Metod system and would like to add a custom backsplash. I am wondering which materials are best suited for a DIY kitchen backsplash that is durable, easy to maintain, and heat-resistant, without the effort or cost becoming excessive. It is also important to me that the backsplash is easy to install and not too heavy, as I will be mounting it myself.
Does anyone have experience or recommendations on whether certain plastic panels, HPL (high-pressure laminate), tiles, glass, wood-based panels, or other materials are better? Are there practical combinations or special installation methods that work particularly well with the Metod system?
I would really appreciate any tips or advice!
GALENKU
17 May 2021 18:35
I would recommend HPL panels. They are durable, easy to cut, and heat-resistant.
pikin
17 May 2021 19:02
For DIY kitchen backsplashes with Metod, the following options are primarily recommended:
- HPL panels: durable, water- and heat-resistant, easy to install by gluing or screwing
- Glass backsplashes: hygienic, easy to clean, heat-resistant, but require professional cutting
- Aluminum composite panels: lightweight, durable, and modern, but somewhat more expensive
- Moisture-resistant wood-based materials with sealing: cheaper, but less durable and require more maintenance
Tiles are a classic choice but are generally more complicated to install and significantly increase the weight.
JORDON
17 May 2021 19:41
Hey Ronsi6! If you want something cool and modern, go for glass – it looks very clean and matches almost any style! 😎
But be careful: glass is heat-resistant, but you have to handle it carefully during installation to avoid scratches or cracks. If you’re handy, it’s best to measure first and then have a glazier cut it to size.
Otherwise, HPL (high-pressure laminate) is also great. You can get really creative with it, and the panels come in dozens of colors and patterns. This way, your backsplash will become a real eye-catcher! 😉
EDWARD0
17 May 2021 20:03
HPL panels are versatile and easy to work with. Glass is more delicate during installation but requires low maintenance. Wood-based materials should only be used with waterproof sealing.
karbar
17 May 2021 20:18
I recommend aluminum composite panels for constructing the back wall. They are lightweight, durable, and heat-resistant. Installation can be done using double-sided tape or screws.
