ᐅ Which materials are best suited for Ikea BRIMNES furniture?
Created on: 13 Feb 2021 20:37
Z
zanderix
Z
zanderix
13 Feb 2021 20:37
Over the past few weeks, I have been researching the IKEA Brimnes furniture series in detail and am now specifically wondering which materials are best suited to maintain its durability and appearance over time. I am interested in possible combinations with certain wall paints, decorative materials, or surface coverings like glass panels or table runners placed on top.
My main challenge is finding a balance between robustness and aesthetic appeal that minimizes stress or damage to the furniture both during assembly and daily use. Has anyone had experience with fabrics, finishes, or coatings that have proven successful? Which materials should be avoided because they might affect the BRIMNES structure or cause unsightly signs of wear?
I look forward to tips and a well-informed discussion, as I would like to get a reliable assessment more quickly.
sanjon
13 Feb 2021 21:46
zanderix schrieb:
Which materials should be avoided because they might damage the BRIMNES structure or cause unattractive wear marks?
Avoid prolonged moisture and harsh cleaning agents. Glass plates work well and protect the surface. Avoid fabrics that are not colorfast, as they can cause stains.
I often use cotton cloths on top, which work well.
O
onMarcos
14 Feb 2021 09:23
Here is a brief overview of which materials work best with IKEA BRIMNES:
- Glass: Ideal as a protective cover. Prevents scratches and moisture damage.
- Cotton: I use it for table runners because it is soft and does not damage the surface.
- MDF and particleboard: Since BRIMNES itself is made of MDF, avoid placing wet materials directly on it, as swelling can occur.
- Painted surfaces: Only tolerate soft cloths for cleaning; otherwise, they may become dull.
Common mistakes include water stains from glass without a protective layer and prolonged color contact from unfixed fabrics.
My advice: Always use coasters or protective layers, regardless of the material, to sustainably prevent damage.
In summary: Choose materials that do not retain moisture and do not mechanically stress the surface.
BeAndrea
15 Feb 2021 14:52
I can confirm that. Additionally, it is important to avoid aggressive chemicals with BRIMNES, as the surfaces can quickly become dull otherwise.
onMarcos schrieb:
Glass: Ideal as a protective surface. Prevents scratches and moisture damage.
If you want to use glass, I recommend placing a soft padding underneath to avoid direct contact with the wood. This helps prevent small damages caused by pressure or movement.
Regarding fabrics, I would especially pay attention to washability and colorfastness, particularly with decorative fabrics or table runners. Otherwise, they can quickly show visible marks.
I personally often use coated cork placemats, which protect surfaces well and are resistant to moisture. For BRIMNES, this is a good combination because cork doesn’t scratch and is breathable at the same time.
In the end, always pay attention to cleaning and protection, and your furniture will stay looking good for a long time.
