ᐅ Which materials are best suited for repairing the surface of an IKEA Besta unit?
Created on: 8 Oct 2024 19:37
moritzkaSome time ago, I bought an IKEA Besta, specifically the model with the white high-gloss finish. Unfortunately, the surface has developed some slight wear and small scratches in several spots, which obviously affects the overall appearance. I want to repair the surface without having to replace the panels or spend a lot on new ones. Therefore, I’m interested in learning which materials and products are best suited for repairing an IKEA Besta surface.
In particular, I want to know how to treat microcracks or scratches, which adhesives, fillers, putties, or surface lacquers work well—especially regarding durability and appearance. What requirements should these materials meet to be compatible with the coated surface? Are there any special repair kits available for high-gloss surfaces from Besta? I would appreciate detailed recommendations, including tips or tricks for application.
A very clear and precise question, thank you for that!
In general: IKEA Besta surfaces are usually melamine-coated or covered with a laminate. This makes repairs a bit more challenging because you want to preserve the surface texture and gloss as much as possible. Here is my structured recommendation:
- For small scratches: A color-matched furniture touch-up pen with a wax base often works very well. These pens are specifically designed to conceal fine scratches.
- For deeper scratches or small chips: Special two-component fillers are suitable here, which can be sanded and then painted over. It is important that they match the material (such as synthetic resin or polyurethane-based).
- For the surface: After using filler or touch-up pen, you can apply a matching clear coat based on acrylic. Clear coats meant for wood are usually not ideal as they tend to become too matte or do not adhere properly.
- Application tips: Thoroughly degrease all surfaces beforehand. Sand very carefully with very fine sandpaper (e.g., grit 600 or higher) to avoid damaging the gloss.
- Do not use solvent-based adhesives or acrylic paints, as these can damage the laminate.
In summary: furniture touch-up pens for superficial damage, two-component filler for deeper damage, followed by a clear coat to seal. Unfortunately, IKEA does not offer their own repair kits, but many hardware stores and specialist dealers provide appropriate products, some even with high-gloss finishes for spraying or rolling.
If you can describe a specific area in more detail, I’d be happy to offer more tailored advice.
Nabla64 schrieb:
For minor scratches: A color-matched furniture touch-up stick with a wax base often works very well.Furniture touch-up sticks are popular, but I would argue that they often only provide a temporary solution and tend to mask the damage visually rather than truly repair it. The surface remains uneven and vulnerable in the end.
I suggest that most DIY repairs on these high-gloss Besta-type surfaces are primarily cosmetic—unless you use professional-grade materials like specialized polyester or epoxy coatings that are specifically designed for these surfaces.
Additionally, if you want to restore the surface to a truly durable state, you should consider completely resealing the repaired area—and this should not be done with standard clear coats from a hardware store, but with transparent, crosslinking polyurethane finishes.
In short—I often find common recommendations for these "furniture touch-up sticks" or standard fillers too superficial to ensure long-term satisfaction.
First and foremost: clean and degrease beforehand.
For minor scratches, use a furniture touch-up pen; for larger holes, use a two-component filler.
After sanding, new scratches tend to appear quickly, so seal with clear lacquer.
Polyurethane lacquer is more durable than acrylic lacquer for heavy use.
I agree with the statements from Nabla64 and likuken but would like to add the following:
When repairing gloss finishes on IKEA Besta components with high-gloss foil, restoring the shine is really challenging. If you use fillers or paints, make sure the products are specifically designed for foil-coated furniture or high-gloss surfaces. Many standard repair kits are not suitable for this.
Here is what I recommend:
- First, carefully prepare the damaged area. This means cleaning with a mild solvent and removing any loose foil fragments.
- For filling, use a two-component polyester filler that offers very high strength and sands well.
- After sanding, roughen the surface with very fine abrasive pads and remove dust.
- Seal with a special transparent, high-gloss polyurethane-based furniture lacquer. The best results are achieved using spray systems to get an even layer.
- Finally, once the lacquer has cured, you can refresh the high-gloss finish with polishing paste.
Another tip: the color of the filler should roughly match the furniture beforehand to avoid needing multiple layers of lacquer.
This way, you will achieve a repair that is both visually appealing and durable.
If you are interested, I can share some recommended product examples that I have personally tested.
