ᐅ Which lighting systems are suitable for illuminating Ikea Besta shelving units?
Created on: 3 Jan 2016 19:03
asgarbe
asgarbe
3 Jan 2016 19:03
Hello everyone, I am currently considering which lighting systems work well to effectively and attractively illuminate Ikea Besta shelves. It is important to me that the light sources are easy to install, have no visible cables, and ideally offer a dimmable function to adjust the brightness flexibly. Additionally, the lighting should optimally illuminate the different compartments without glare or casting shadows. Does anyone have experience with specific LED strips, spotlights, or other types of lamps that are particularly suitable for this purpose? I am also interested in practical power supply and control options, especially regarding Besta shelves with glass or wooden elements. I am open to all tips, recommendations, and critical assessments.
Penau
3 Jan 2016 20:16
Basically, LED light strips are the best choice for lighting Ikea Besta shelves because they are slim and can be easily attached along the inner edges. Cold white LEDs with around 4000 Kelvin are especially recommended, as they produce a neutral, clear light without distorting the colors of the shelf contents. Make sure the strips have a sufficiently high brightness (at least 300 lumens per meter). Integration into the electrical system is usually possible via 12-volt transformers and plug-in power supplies, which can be hidden inside the furniture. Dimming functions can be implemented either directly with 12 V dimmers or remotely using appropriate controllers. Special spotlights are better suited for accent lighting on glass shelves but are generally more complex to install.
fidasi
4 Jan 2016 08:38
Penau schrieb:
Basically, LED light strips are the best choice for illuminating Ikea Besta shelves because they are slim and can be easily attached to the inner edges.
I fully agree and would like to add some more technical details to help you make an informed decision: LED light strips are usually available in 12V or 24V versions, with 24V systems often providing more even lighting and experiencing lower power loss over longer shelves. For Besta shelves, flexible LED strips with an IP20 rating are most common, meaning they are suitable for indoor use without high humidity.
For installation, it’s best to use double-sided tape or small clips to mount the strips as invisibly as possible. Positioning also plays a role: I recommend attaching the strips along the upper inner edge so the light evenly shines downward, reducing shadows caused by objects. An alternative option is aluminum LED profiles, which act as heat sinks and create a diffused light distribution.
Regarding control, a simple power supply and dimmer can be sufficient if you prefer a wired setup. If you want more flexibility, smart controllers (e.g., operated via wireless or Bluetooth) are a good choice, though they tend to be more expensive. Additionally, the choice depends on the cabinet material: glass shelves reflect the light and enhance brightness, while wood can create shadows, so it’s better to pay attention to light color and uniformity.
One last question: How long are your Besta shelves, and do you plan to illuminate internal compartments with doors or open ones?
asgarbe
4 Jan 2016 10:57
fidasi schrieb:
One final question: How long are your Besta shelves, and are you planning the illumination for compartments with doors or open ones?
Thanks for the detailed information. My Besta shelves are each 120cm (47 inches) wide and about 40cm (16 inches) deep. Most compartments have glass doors, some are open. I want the lighting to create a more uniform brightness impression rather than individual light spots. Leaving cables visible is not an option, so internal cable management inside the shelf itself would be ideal, or a solution with cable channels on the back. Dimming should be done via remote control, so I don't have to adjust it directly at the furniture.
blaix
5 Jan 2016 11:12
I am somewhat skeptical about cold white being the best choice. While 4000 Kelvin is indeed neutral, warm white (2700-3000 Kelvin) is often preferred in living areas because it feels more comfortable. Especially for shelves displaying hobbies, books, or collectibles, this type of lighting can create a cozier atmosphere. Additionally, I see advantages in using multicolor or RGB LEDs, which allow you to adjust the lighting according to the mood—though this naturally increases installation effort and complexity.
What about energy consumption? Some LED strips consume unnecessarily high amounts of power when left on continuously. Does anyone have specific efficiency figures or better alternatives to traditional LED strips?
BLAKEO
5 Jan 2016 13:47
blaix schrieb:
I am skeptical about whether cool white is really the best choice.
I agree with this. The perception of light color is subjective; however, generally speaking, neutral white is better for work areas or clear visibility, while warm white is preferred for living rooms or ambient lighting.
Regarding power consumption: modern LED strips with SMD 3528 or 2835 LEDs typically consume around 4–7 watts per meter (3–2.1 watts per foot). High-power LEDs are more efficient and require less wattage for the same brightness. However, they generate more heat, which should be considered when installed in built-in furniture.
On the other hand, RGB LEDs are stylish but do not provide optimal color rendering for functional or decorative objects. Therefore, I recommend using multiple light sources or a combination depending on the intended use. What are your experiences with this?
