ᐅ Which type of light switches are compatible with Philips Hue lamps?
Created on: 18 Jan 2023 13:06
Taitv789
we are looking for suitable light switches for Philips Hue lamps.
Which light switches can you recommend that are compatible with Philips Hue lights and Matter?
If possible, we prefer a push button rather than a traditional light switch, one that returns to a neutral position after each press.
The light switches should be programmable with different functions (controlling various lamps and different dim levels) and continue to supply constant power to the lamps, sending only the signal to turn the lamp off.
The switch definitely needs to be powered by mains electricity and not battery-operated like the official Hue switch.
O
os24laenger22 Jan 2023 09:40We have been using Busch-Jaeger Light Link for 8 years. If you manage to program it (which is quite complicated), it actually works pretty well. We control about 20 Hue lamps with it, and the dimmers and switches (for regular lamps) can also be operated via the Hue Bridge. Alternatively, you can check out Dresden Elektronik.
