I am currently planning to equip my Ikea Besta cabinet fronts with LEDs to create modern yet practical lighting. I am wondering: which LEDs are particularly well suited for lighting Ikea Besta furniture?
What is especially important to me:
- Good color rendering (CRI) for optimal color accuracy.
- Light that is as glare-free and comfortable as possible.
- Easy installation inside or on the furniture.
- Compatibility with 12V or 24V power supplies that are easy to use.
- Optional dimmable functionality to adjust the lighting mood flexibly.
Perhaps someone here has experience with suitable LED strips, spot LEDs, or other solutions specifically for Besta furniture?
I would also appreciate tips on brands or module types that have proven reliable.
Thanks in advance for your suggestions and recommendations!
lubla schrieb:
I would recommend LED strips with 3000K warm white, as they best match most Besta colors.That is basically a good starting point!
To add:
- For the Besta furniture, I recommend LED strips with a minimum brightness of 800–1000 lumens per meter (about 244–305 lumens per foot) to provide enough illumination without being too harsh.
- A CRI above 90 is better for living room or residential use, as color accuracy is more important there.
- An IP20 rating is usually sufficient, as long as the strips are installed inside the furniture and not exposed to moisture.
- Regarding installation: Most Besta furniture unfortunately does not have dedicated channels, so it is advisable to mount the LED strips onto aluminum profiles, which can also act as heat sinks.
- Dimmability is possible with suitable LED controllers and power supplies—for example, constant voltage power supplies with 12V DC and PWM dimmers.
One more tip: If you want more accent lighting, you can also use individual LED spots with warm white at 2700–3000K, which can be recessed into the shelves.
How exactly do you plan the installation and where do you want to position the LEDs? That way, the recommendations can be fine-tuned.
glamo schrieb:
How exactly are you planning to install the LEDs and where do you want to position them? This way, the recommendations can be more precise.Thank you for the detailed information, glamo!
I plan to attach LED strips mainly along the inner edges of the Besta cabinet panels to create indirect lighting that subtly illuminates the fronts. Additionally, I want to light selected shelves with LED spotlights to highlight displayed items more effectively.
As for the installation method, I don’t have a specific solution yet, but I am considering using aluminum channels as you suggested to ensure better heat dissipation and an even light distribution.
Regarding the power supply: a 12V system seems practical, but from your perspective, are there reasons to consider switching to a 24V system?
I look forward to your input and any further advice, especially about combining strips and spotlights within the Ikea Besta setup.
chenna8 schrieb:
Regarding the power supply: A 12V solution sounds practical, but do you see any reasons to switch to 24V systems?I think this is an important aspect that is often underestimated. 24V LED systems have several advantages, especially when longer runs are involved:
- Less voltage drop over long cables, resulting in more uniform brightness.
- Generally lower current for the same power, which allows for thinner cables and less heat generation.
- Sometimes better compatibility with high-quality dimmers and control systems.
However, 24V systems are not necessarily required for small, compact furniture like Besta and can be somewhat more complicated when it comes to replacement parts or expansions.
I would also base the decision on how many meters of LED strips you plan to use. Less than 5 meters (16 feet) 12V is usually fine, but beyond that 24V tends to be the more technically sound choice.
Finally, make sure to use good power supplies with protection features—cheap products are often unreliable and can damage the LEDs.
