ᐅ Which LED lights are well suited for illuminating Ikea BESTA shelves?
Created on: 25 Apr 2015 19:37
klatoHello everyone,
I recently bought an Ikea Besta shelving unit and am currently looking for suitable LED lights to illuminate it optimally. It’s important for me to find a solution that provides enough light to properly brighten the shelves while also fitting well with the modern, clean design of the Besta.
I am particularly interested in LED strips or small LED spotlights that are easy to install and preferably have no visible cables. Has anyone had experience with specific LED lighting options that work especially well for these shelves?
Which color temperature (warm white, neutral white, cool white) would you recommend to avoid a too artificial look while still ensuring good visibility?
I’m looking forward to your tips on brands, models, or perhaps even DIY solutions you can recommend. Thank you in advance!
From my experience, when using IKEA BESTA shelves, LED strips with a high CRI (color rendering index) of over 90 are especially recommended. This ensures the lighting looks natural, even if you want to display light-colored decorative items or artwork on the shelves.
Here is my recommendation: Warm white (2700–3000 K) creates a cozy atmosphere that fits well in living areas. Neutral white (around 4000 K) appears more modern and clear without feeling too cold. I would not recommend cool white (above 5000 K) for this application—it often appears too sterile and uninviting.
During installation: Make sure the LED strips are mounted into an aluminum profile channel that also acts as a heat sink. This significantly extends the lifespan of the LEDs and ensures an even light distribution.
klato schrieb:
Which color temperature (warm white, neutral white, cool white) would you recommend so that the lighting does not look too artificial but is still clearly visible?
I also spent some time researching this topic because I wanted to equip my BESTA dresser with LEDs. I was uncertain about whether the light color should be too cool or too warm and how the light would look behind glass.
I agree, especially if you spend a lot of time in the room. Maybe you could also consider using dimmable LED strips so you can adjust the lighting to the time of day. Another important factor for me was easy installation: I chose flexible LED strips that can be securely attached under shelves with double-sided tape.
It’s really a nice way to enhance the shelves, and I think it makes a big impact, especially when displaying books or decorative items. If anyone has good experience with Bluetooth-controlled lighting or similar smart solutions, I’d be interested to hear about it.
flota schrieb:
Warm white (2700-3000 K) creates a cozy atmosphere that works well in living areas.
Issac_kla226 Apr 2015 11:17I’m looking at this from a slightly different perspective. Discussions about “which LEDs work best with Ikea BESTA” often seem a bit overcomplicated to me. Sure, the products are stylish and the lighting can look great, but in my opinion, too much focus is put on trendy details.
Honestly, the cables are the least of your worries if you really want good lighting. Many overly thin LED strips tend to look more like party decorations rather than quality room lighting.
Also: why the constant urge for “invisibility”? You always see some technology and cables somewhere. I would rather recommend small but powerful spotlights that create real highlights—rather than endless strip lights, which often only provide flickering light and are often of inferior quality.
Of course, it’s a matter of personal taste, just something to think about.
klato schrieb:
I’m mainly interested in LED strips or small LED spotlights that are easy to install and have as few visible cables as possible.
Hello klato,
to be more specific, I would need to know exactly how you have designed your BESTA (compartment dimensions, whether with or without glass doors, what kind of power supply you can use, etc.). These details are important because they significantly influence the choice of suitable LED lights.
Generally, I recommend the following approach:
- LED type: For shelf lighting, flexible LED strips (preferably 12 V version) are best suited because they can be installed in various locations easily. Look for a high LED density (at least 60 LEDs per meter) to achieve even lighting.
- Color temperature: Warm white (2700-3000 K) creates a cozy atmosphere, neutral white (~4000 K) is easier on the eyes for extended viewing, cool white (>5000 K) is good for work areas. For living spaces, 3000-4000 K is a good compromise.
- Use linear aluminum profiles. These not only provide cooling but also better light diffusion and easy installation.
- Wiring: Ideally hidden and combined with a small power supply (possibly external to avoid heat buildup inside the cabinet).
- Control: If desired, you can choose dimmable or remote-controlled LED systems.
If you can provide details such as the maximum installation depth for the LEDs and space for cables, I could give you more targeted recommendations.
