ᐅ Which LED lighting is best suited for Ikea PAX wardrobes?
Created on: 7 Aug 2019 19:23
joankeo
joankeo
7 Aug 2019 19:23
Hello everyone, I am considering which LED lighting is best suited for the Ikea Pax wardrobe system. My main focus is on achieving a pleasant but bright illumination that either turns on automatically when the wardrobe doors are opened or can be operated via a smart switch. Additionally, the solution should be as easy to install as possible since I want to avoid complicated installations. How have you solved this? Which LED systems are compatible and offer good value for money? I look forward to your experiences and recommendations.
TRA33
7 Aug 2019 20:12
I installed strip LEDs under the shelves of my Pax unit, which are controlled by a motion sensor. Simply screw them in, route the cables, and you’re done. It works reliably and looks good.
raquel52
7 Aug 2019 21:07
Regarding LED lighting for Ikea Pax wardrobes, I recommend using warm white LED strips with a color temperature of 3000 Kelvin, as they provide a pleasant, not overly cold light. For automation, PIR motion sensors or door contact switches work well to activate the lights as soon as the wardrobe door is opened. Self-adhesive LED strips operating at 12V are particularly effective because they are easy to install and do not require a transformer that generates high heat. Make sure not to stick the LED strips directly onto wood; instead, use an aluminum profile as a heat sink to extend their lifespan.
RENMA
7 Aug 2019 22:48
An important aspect when choosing LED lighting for the Ikea Pax is the power supply. Many users underestimate that battery-operated portable solutions are either too weak or require frequent battery changes, which can become inconvenient over time. Fixed 12V systems with a power adapter are recommended. The color temperature should be between 2700-3500 Kelvin to ensure natural color rendering inside the wardrobe. Additionally, I recommend integrating diffusers or covers to prevent glare. LED profiles with built-in opal covers are especially suitable, as they diffuse the light softly and evenly.
tutan
8 Aug 2019 07:30
I installed a combination of LED panels and flexible strips in my Pax wardrobe – it might sound like a lot, but the effect is fantastic! 🌟 The panels on the ceiling of the wardrobe provide general illumination, while the strips along the sides create accent lighting. And yes, thanks to the door sensors, they turn on as soon as you open it. You can imagine: half asleep in the morning, lights on, and no more searching around 😀.
SUDAN
8 Aug 2019 09:44
Regarding the question of suitable LED lighting for the Ikea Pax system, there are basically different approaches. I would like to provide a brief guide with common options and their advantages and disadvantages:
- LED strips with self-adhesive backing: Advantages include easy installation and even light distribution. Disadvantages can be insufficient cooling and adhesive issues.
- LED panels: Provide diffuse lighting and look professional but are usually more expensive and require more planning effort.
- Spotlights with motion sensors: Offer very targeted lighting, ideal for areas where spot lighting is needed. Installation effort is higher.
In general, I recommend a combination of a 12V power supply, warm white LEDs (2700–3000K), and sensor-controlled activation to save energy and increase comfort. One final tip: plan the cable routing carefully beforehand and check whether the adapter can be placed discreetly inside the wardrobe.
