Hello!
Our construction started about 2.5 weeks ago, and we are currently planning the electrical system. We are wondering how to install internet in the house.
About the house:
The house is built using solid construction methods from Viebrockhaus. Radio waves barely pass through the ceiling between the ground floor (GF) and the upper floor (UF). On the UF, the interior walls are drywall with metal elements, which also blocks radio waves significantly.
For the ground floor:
We want to set up Wi-Fi with the router located in the utility room. This should provide coverage throughout the entire ground floor and help reduce electromagnetic pollution to some extent.
For the upper floor:
This question is more complex. We lean toward a LAN solution to minimize electromagnetic pollution.
Option 1: Run LAN cables through the empty conduits from the utility room to each room on the upper floor.
Option 2: Use powerline adapters (network over the electrical wiring).
-> We tend to choose the second option because there are more power outlets than LAN ports in each room. It is also somewhat cheaper, though the price difference is minor in a project of this scale.
What do you think? Will this solution work without problems, or are there limitations? Have you had any experience with this?
Thank you very much for your input.
About the house:
RobsonMKK schrieb:
Do it right or not at all. Wi-Fi has no place in new construction.OK, thanks for your response. What is wrong with Wi-Fi? Why does it have no place in new construction?
I’m interested in that as well. I didn’t have any LAN cables installed; instead, I use Wi-Fi. This saved me an extra LAN socket and all the wiring, and there’s no risk of a network cable breaking. Bandwidth isn’t an issue either—we use it for streaming services, and the bandwidth easily supports two HD streams plus one SD stream.
So where exactly are the disadvantages, apart from the fact that you do need the devices? As I said, I don’t have the risk of a cable breaking at some point.
