ᐅ Which interior wall material and thickness provide good sound insulation?
Created on: 20 Jan 2014 12:23
kirsel
kirsel
20 Jan 2014 12:23
We are currently planning a two-story single-family house with our architect, with approximately 160m² (1,722 sq ft) of living space.
The exterior walls are planned to be made of 36.5cm (14.4 inches) Poroton bricks.
When children eventually reach the relevant age, sound insulation of the interior walls will definitely become very important. Which materials have particularly good properties for this purpose? And what thickness is ideally used for these materials?
Bauexperte
20 Jan 2014 12:37
kirsel schrieb:
We are currently planning a two-story single-family house with about 160 square meters (1,722 square feet) of living space together with our architect.
The exterior walls are planned to be made of 36.5 cm (14.4 inches) Poroton bricks.
When children reach the appropriate age, sound insulation of the interior walls will certainly become very important. Which materials offer particularly good properties for this? And what thickness would be optimal for installation?
What is your architect’s recommendation?
Regards, Bauexperte
kirsel
20 Jan 2014 12:44
We haven’t discussed interior walls in sufficient detail yet. However, that shouldn’t matter for a purely fact-based recommendation, right?
kirsel
20 Jan 2014 13:53
You’re always using your abbreviations. What exactly does “Hochlochziegel” mean?
By the way, the upper floor (OG) is actually the ground floor (EG) at street level, covered by a mono-pitched roof (due to the sloping site). That’s why the garden side has a height of 3.70 meters (12 feet 2 inches). The space is completely open except for the staircase in the center. Interior walls are needed downstairs to divide the rooms. Why can’t I combine Poroton bricks on the outside with calcium silicate bricks on the inside?
E.Curb
20 Jan 2014 21:15
kirsel schrieb:
Why can’t I combine Poroton on the outside with sand-lime brick on the inside?
Because one is a fired clay brick and the other is not. Both building materials behave differently in terms of movement. Therefore, these two materials should not be mixed.
stefanh
22 Jan 2014 07:41
I'm currently in a similar situation!
According to the plan, the children's rooms are “only” separated by an 11.5 cm (5 inch) load-bearing brick wall. This raises the question for me whether the sound insulation is sufficient.
According to a manufacturer’s page for soundproof bricks (SMZ), it states – quote: “Enhanced sound insulation according to DIN 4109, Supplement 2 (R' W ≥ 55 dB) depending on local conditions.”
Does this mean, conversely, that load-bearing bricks without special soundproofing provide up to 55 dB of “quiet”?
Since I’m meeting with a shell construction company tomorrow evening, I will raise this topic there as well. I will also mention the lightweight construction method suggested by the building expert as a proposal (in case the shell builder doesn’t come up with it themselves)...
Hollow bricks = hollow bricks?
