ᐅ Which impact sound insulation is suitable for underfloor heating?
Created on: 8 Nov 2017 10:14
Curly
we are about to install laminate or engineered wood flooring in the children's rooms and the master bedroom area. So far, we have always used a 5mm (0.2 inch) impact sound insulation underlay or fully glued the parquet. However, now that we have underfloor heating, the floor build-up should allow heat to pass through as efficiently as possible.
Is there a specific type of impact sound insulation that works well with underfloor heating, and what thickness would you recommend? Have you had good experiences with certain products?
Sabine
Sabine
Deliverer schrieb:
But as I said, a barely measurable small one. If that were the case, it would also be barely measurable if you simply covered your radiators at home with an underlay for parquet flooring. Would you do that? According to your theory, it wouldn’t lead to a noticeably higher energy consumption!?!
Deliverer13 Nov 2017 22:04Bieber0815 schrieb:
... would result in a higher return temperature ...Thank you.D
Deliverer13 Nov 2017 22:11wieli schrieb:
If that were the case, it would hardly be measurable if you simply covered your radiators at home with a parquet underlay. Would you do that? According to your theory, it wouldn’t result in any noticeable increase in energy consumption, right?! That is exactly my assumption.
Although, to fully illustrate the example, I would first place 1.5 mm (0.06 inches) of plastic, 5 cm (2 inches) of screed, 4 mm (0.16 inches) of softwood, 5 mm (0.2 inches) of plywood, and 3 mm (0.12 inches) of hardwood over the radiator. Then I would measure the difference that occurs when I squeeze an additional 2 mm (0.08 inches) of impact sound insulation in between.
