ᐅ Which Ikea tools are helpful for assembling Pax wardrobes?
Created on: 11 May 2017 09:22
Gako63
Gako63
11 May 2017 09:22
I am currently planning to assemble a Pax wardrobe from Ikea and am unsure which of Ikea’s tools are truly helpful to make the assembly as efficient and precise as possible. Since the assembly instructions usually only list the basic tools, I am especially interested in which tools from Ikea’s range, in my opinion, can make handling the Pax components easier – particularly with the heavier wardrobe parts and the sliding doors. Does anyone have practical experience with Ikea’s own screwdrivers, cordless drills, assembly aids, or other tools like special keys and dowel sets that are specifically recommended for assembling the Pax? I would appreciate a detailed list along with a brief assessment of which tools are essential and which ones might be unnecessary. Thank you very much!
Tarmau
11 May 2017 10:37
Regarding the question about Ikea tools that help when assembling Pax, here is my structured response:
- Cordless drill: Not from Ikea itself but useful. It allows screws to be driven faster and more securely, especially with the sturdy side panels.
- A small hex key (Allen wrench) is included in the delivery, which is generally sufficient to make all connections. The quality of the Ikea key is solid, but it is somewhat small for long-term use.
- For the sliding doors in particular, a long Phillips screwdriver is recommended, as some screws are difficult to reach.
- Some users recommend the Ikea “FIXA” tool set, which contains inexpensive screwdrivers and pliers. This set is ideal for minor adjustments and tightening screws.
- When installing the clothes rails and shelves, a light rubber mallet can be helpful for fitting parts in without damaging them.
Summary: The included tools are enough if you are patient. However, it is sensible to have your own medium-sized Phillips screwdriver, a cordless drill, and possibly a small hammer or plier set from Ikea FIXA. Tools like drills with bits are not required for the Pax kit.
RUBEN54
12 May 2017 14:49
Tarmau schrieb:
A small Allen key is included, which is generally sufficient to assemble all the connections.
That is correct, but I would like to add that when installing the sliding doors, a longer screwdriver is often necessary because the screws are frequently set deeper.
- Step 1: Use the small Allen key to assemble the main frame. The parts fit well; carefully tightening the screws prevents damage.
- Step 2: For the back panels and side strips, use a Phillips screwdriver, as larger screws are usually used here.
- Step 3: When fitting the sliding doors, a magnetic pickup tool can be helpful if screws fall into gaps.
Common mistakes include overtightening screws with the small Allen key, which can damage the screw heads. It is better to proceed with caution.
Tip: The IKEA FIXA set is ideal for assembly. It is affordable, includes a good screwdriver, and also has pliers that can be useful later when adjusting the cabinet.
Conclusion: For those who want to avoid purchasing a cordless drill, at minimum keep a long Phillips screwdriver and the included Allen key on hand, supplemented by the FIXA kit for best results.
SINEL
13 May 2017 08:11
Gako63 schrieb:
Does anyone have practical experience with Ikea’s own screwdrivers, cordless drills, assembly aids, or other tools like special keys and dowel sets specifically recommended for assembling Pax?
The Pax system is designed so that the included hex key is sufficient. A separate Phillips screwdriver is useful for the side panels and sliding doors. Everything else is mostly optional. A cordless drill saves time but is not essential.
