ᐅ Which IKEA PLATSA units are suitable for use as TV furniture?
Created on: 31 Dec 2021 13:27
JONOJON
I am planning my new living room setup using the IKEA Platsa system and am considering which modules are best suited as TV furniture. It is important for me to have enough storage space for media devices, a stable surface for TVs up to around 65 inches, and a fairly high degree of flexibility in the arrangement (for example, combining open and closed elements).
Who has experience using Platsa as TV furniture?
Which combinations and modules have you used, and how did you solve the design and functional aspects?
Are there recommendations for modules that work particularly well for cable management, since I want to connect many devices?
I look forward to your tips and insights regarding the load-bearing capacity and practical aspects of the system.
PULAU
2 Jan 2022 14:56
flota schrieb:
The load capacity is typically around 50 kg (110 lbs), which is sufficient for most televisions.
That is correct. Additionally, I would point out that with Platsa, a modular extension also distributes tensile loads, which increases stability.
For TV furniture, I recommend a combination of base modules and narrow side panels to ensure the overall width is correct and the unit, especially with larger televisions, does not wobble.
Furthermore, fixed wall mounting or using back panels for reinforcement significantly improves stability.
letar
3 Jan 2022 10:29
Specifically regarding the system: The PLATSA base units measuring 120x40 cm (47x16 inches) are the common standard for TV furniture.
It is recommended to use modules that combine open shelves and doors, allowing devices such as receivers or consoles to be visible yet neatly stored.
In terms of design, a combination of white or light-colored carcasses and fronts has proven effective, which can be complemented with wooden elements or colored doors.
For cable management: Make sure to choose modules with back panels that have pre-made cable openings or offer these as optional additions. This greatly simplifies hiding cables while maintaining airflow.
One possible setup could be, for example, two 120 cm (47 inches) base units placed side by side, each featuring open shelves at the top and doors or drawers at the bottom for better organization.
This creates a clean, streamlined appearance with plenty of storage space and functionality.
