In recent days, I have been looking closely into Ikea Pax wardrobes because I am searching for new doors for my bedroom wardrobe. I am mainly interested in which of the many doors offered in the series are the most stable, as I value long-lasting use and often open and close the doors. Specifically, I am asking: Which Ikea Pax wardrobe doors provide the highest stability and durability for everyday use, especially regarding material thickness, hinges, and frame construction? I want to avoid door frames warping or doors sagging, which may happen with cheaper models. It would be great if you could share your experiences or well-founded assessments, including any notes on common weaknesses and tips for optimal selection. Thanks!
This is a very important question, especially since, as you mentioned, the doors are used frequently. I was also initially concerned about whether cheaper doors would hold up in the long run. In my experience, doors with a durable solid wood frame (for example, framed fronts and some solid wood doors) are significantly more stable than those made entirely of particleboard or plastic fronts. The hinges on Pax units are generally quite high quality, but if the door is lighter, it can warp more quickly.
For this reason, I would recommend a combination of a solid frame construction with a filling made of MDF or a similar material. I once chose doors with mirrors, but you need to be a bit more careful with those because the weight distribution is different. Overall, I can only say this: stability can also be felt in the door’s weight – too light is usually not good, but if it’s too heavy, you have to make sure the hinge and frame can support it.
Hope this helps!
Hope this helps!
Franklin3612 Oct 2017 09:46To better answer your question about the stability of Ikea Pax cabinet doors, here is a structured overview:
- Solid wood frame doors: These are often more stable than other types because the frame is made of real wood, which prevents warping and also holds hinges better.
- High-gloss and lacquered fronts: These usually consist of MDF or particleboard with a plastic coating. While visually appealing, they tend to warp under high humidity or heavy use.
- Mirror doors: These are heavier and should only be used with strong hinges to avoid sagging.
Common issues include door bending and hinge loosening. Ikea offers reinforced hinges for heavy doors, which is recommended for large cabinet doors.
A tip: When assembling, make sure to properly adjust the hinges and ensure the door is mounted securely to maintain stability.
In summary, solid wood frame fronts are the most stable, followed by solid MDF doors, while very thin particleboard or plastic doors tend to be less durable.
Franklin36 schrieb:
A tip: When assembling, carefully adjust the hinges and ensure the door is mounted securely to guarantee stability.I definitely want to add this because many people tend to overlook this crucial point.
The stability of a Pax wardrobe door depends not only on the material and hinges but also on the proper installation of the door front and the stresses caused by everyday use. Besides recommending more solid frame fronts, it is important to use the correct number of hinges: always use two per side for doors wider than 50 cm (20 inches), and even more for very large doors.
Additionally, consider the following details when handling:
- The hinges have adjustment options to align the door panel precisely, which prevents warping and sagging.
- Sometimes, with changes in humidity, MDF or other engineered wood panels can warp slightly, so careful control of indoor climate is not unimportant.
- For special versions like mirrored or glass fronts, the weight is higher, and stability mainly depends on the fittings. Therefore, stronger hinge attachment and possibly a crossbar are recommended for very tall doors.
Question: What cabinet size and door types are you planning? This is important to provide more targeted advice since wider doors generally require greater stability.
