ᐅ Which Ikea PAX wardrobe doors are the quietest?
Created on: 30 Dec 2016 18:37
Li_neo32
Li_neo32
30 Dec 2016 18:37
I am currently considering purchasing an Ikea PAX wardrobe and have come across the different door systems. My main question is which PAX wardrobe doors operate the most quietly.
It is important to me that the doors are as noise-free as possible when opening and closing, since the wardrobe will be placed in a bedroom, where loud noises can quickly become disturbing—especially when trying to work or read quietly in the evening.
Are there any experiences regarding whether doors with a soft-close feature are significantly quieter than standard doors or sliding doors? Or are mirrored doors or other surface types perhaps easier to operate quietly?
I am also interested in whether the smoothness of operation depends on the wardrobe’s size or depth, or mainly on the door type.
I would greatly appreciate detailed feedback, not just general recommendations, but also technical explanations or tips on how to minimize noise.
Thanks in advance!
risar
31 Dec 2016 07:29
Li_neo32 schrieb:
My main question is which PAX wardrobe doors are particularly quiet to operate.
That is a very good and detailed question. Basically, the soft-close doors from Ikea for PAX are specifically designed to avoid the typical slamming noise when closing.
- The models with soft-close hinges have built-in damping within the hinge mechanism that significantly slows down the closing and cushions it gently.
- For sliding doors, the noise level mainly depends on the track and rollers – the better and smoother the rollers run, the quieter the door movement.
- The material surface can also have a minor effect: high-gloss finishes or mirrors reflect sound but hardly affect the noise when opening or closing.
Additionally, I would recommend fitting rubber bumpers or damping strips afterwards if the factory-installed dampers are not sufficient.
Regarding the wardrobe size: larger doors usually weigh more and require stronger hinges or rollers. This can affect how quietly they operate because of the increased momentum. But basically, the door mechanism plays a bigger role in noise generation than the cabinet dimensions.
I hope this helps you as an initial assessment!
matthewon
1 Jan 2017 13:02
risar schrieb:
Models with soft-close hinges have an integrated damping mechanism within the hinge that significantly slows down and gently cushions the closing action.
I have to honestly disagree a bit, at least when considering the price and expectations. The soft-close doors offered by Ikea are okay, but anyone expecting them to compete with higher-end furniture or specialized fittings might have been influenced too much by marketing claims.
In my experience, there is often a clearly audible, though softened, noise when closing and opening. The smoothness of the operation is rather average. Retrofitting or using higher-quality hinges is often the better choice, not just adding an extra rubber buffer.
I fully agree with this point; sliding doors are a special case here. I find they are often quieter than standard hinged doors because the opening motion is smoother – provided the tracks are clean and free of dust.
Regarding the size: I see it similarly to risar, but I would rather say that the larger the door, the more challenging it is to maintain smooth operation. I would have liked more precision in the original post regarding which sizes or door types particularly interest you.
This topic is more interesting than it might seem!
klo40
2 Jan 2017 21:44
A good discussion here! To clarify a bit, I will summarize from a technical perspective the factors that influence the smoothness and quietness of Ikea PAX doors:
1. Door type
- Hinged doors with soft-close hinges: These are the quietest when closing because the integrated damper catches the door and slows it down in a controlled way.
- Standard hinged doors without soft-close have the typical closing sound.
- Sliding doors: The smoothness and quietness largely depend on the tracks, rollers, and their maintenance. Cleanliness and proper adjustment are crucial here.
2. Material and weight
- Mirror and high-gloss fronts are usually heavier, which can slightly increase the noise when closing, but soft-close reduces this.
- Lightweight doors (e.g., with melamine coating) are sometimes quieter in handling, though this difference is less noticeable.
3. Cabinet size
- Larger doors require sturdier fittings and dampers, which need to be optimally adjusted. Incorrectly aligned hinges can be noisy.
4. Retrofitting/tuning
- Rubber bumpers on the edges can help reduce impact noise.
- Lubricating hinges with appropriate silicone spray reduces friction noise.
In summary: For maximum smoothness and quietness, it is best to choose soft-close hinged doors, adjust and maintain them regularly. Sliding doors can be very quiet if the rollers run smoothly but require a bit more care.
If you like, I can also provide a short guide on how to readjust the PAX soft-close hinges.
