ᐅ Which Ikea Pax options are known for their durability?
Created on: 11 Nov 2022 08:37
klaus53
Hello everyone, I am considering getting a new Pax system from Ikea and am having some difficulty distinguishing the truly durable models among the many options. My specific question is: which IKEA Pax variants are considered particularly long-lasting, especially in terms of material quality and workmanship? I am mainly interested in sturdy carcass materials, robust doors, and durable hinges, as the wardrobe will be used frequently. Are there certain Pax series or fronts that are known to show less wear despite heavy use? Additionally, it would be helpful to know if any models or combinations require more attention in terms of maintenance or assembly to maximize their lifespan. Thanks in advance!
Domau0
12 Nov 2022 11:28
For further insight: The durability of a Pax system depends not only on the choice of materials and construction but also significantly on the environment and the intended use. If the furniture is placed against an exterior wall with high humidity, additional ventilation should be considered, as wood-based materials can swell. Regarding the doors, the signature edge profiles of the frame fronts are more stable because they better distribute mechanical stresses and, through the joint, can compensate for potential deformation. Installation is particularly critical at this point: the screw connections must be precisely aligned at the correct angle; otherwise, the frame may suffer over time. Another tip: use screws with a locking torque to prevent loosening over time. If you prefer Pax with sliding doors, make sure the tracks are professionally installed and decoupled with mounting foam to avoid vibrations and scratches on the surfaces. Almost every step is important if you want to maintain robustness. I would be interested to know exactly how you plan to use your Pax system so I can provide more targeted advice on the suitable options.
klaus53
12 Nov 2022 12:45
Domau0 schrieb:
I’m interested in exactly how you plan to use your PAX system so I can better address the suitable options.
Thanks for the detailed information! I intend to use the PAX mainly for storing clothing and shoes—not just clothes but also heavier shoes and bags. Therefore, it needs to support a considerable amount of weight without shelves or hinges bending. I prefer doors because I find sliding doors somewhat problematic, but I don’t have a clear idea yet about the front materials, other than that they should be durable. Are there specific types of fronts that work best in terms of load capacity and maintenance? Also, regarding the cabinet depths—does it make sense to compromise on stability to save space, or is it better to invest in a deeper, more stable unit?
