ᐅ Which Ikea Pax wardrobe variants are especially durable for everyday use?
Created on: 21 Apr 2023 09:17
nonfoI am currently considering purchasing an Ikea Pax wardrobe, which will be used daily. It is especially important to me that the chosen version or specific material is as durable and long-lasting as possible, since the wardrobe will be opened, closed, and sometimes subjected to heavier use regularly. My specific question is: Based on your experience, which Ikea Pax options—such as materials, doors (sliding doors vs. hinged doors), interior fittings, or any special reinforcements—are particularly durable and resistant to daily use? Are there certain combinations that have proven to be especially sturdy in everyday use, or can you notice clear quality differences between specific models? I look forward to your informed opinions and experiences, as making a reliable decision is very important to me.
Hello nonfo, that is a very well-considered question. Basically, with the Ikea Pax system, stability and durability depend not only on the basic version but also on proper installation. Sliding doors are often seen as less durable because the tracks and rollers tend to wear out more easily. Hinged doors usually last longer, especially if they are made from solid wood or painted MDF rather than simple particleboard material.
Additionally, it should be noted that interior fittings with metal components, such as clothes rails and glass shelves, are less prone to twisting, which improves load-bearing capacity. For frequent use, I also recommend installing internal reinforcements, like additional crossbars – these are not standard but can help significantly.
As a former specialist advisor said: “Pax is modular, so it’s best to adapt the entire system to your own usage – those who frequently load and unload daily should focus on strong mechanical furniture parts and upgrade them if necessary.”
cassandra21 Apr 2023 11:33As an addition: It is worth paying attention to the load-bearing specifications of Pax components.
- The back panels made of thin particleboard can warp under heavy use.
- MDF doors are more expensive but show less deformation compared to particleboard doors.
- Sliding doors require precise guide rails, which can wear out with frequent use, leading to jamming or difficult operation.
For intensive use, a sturdy hinged door with durable hinges and a painted surface is a better choice. Metal shelves and reinforcement kits for the frame parts also increase durability.
For the interior fittings, I would recommend metal rods for hanging and metal shelves instead of simple wooden options.
I have been using a Pax wardrobe with sliding doors made of particleboard for 3 years. At first, I was satisfied, but over time the doors have become increasingly difficult to operate, the rollers have worn out, and one door is now slightly misaligned.
That is exactly what happened to me. In my experience, sliding doors are not the best choice for wardrobes that are heavily used. On the other hand, I prefer the look compared to hinged doors, so I am considering possibly replacing the doors and adjusting the interior fittings.
In my experience, besides the door type, wall thickness and the frame also play a crucial role in durability.
A more robust frame prevents the cabinet from warping with frequent opening and closing. The Pax models with metal frames or reinforced side panels offer significant advantages in this area.
Exactly, retrofitting reinforcements makes sense if you want maximum stability. Mounting on level, solid floors also prevents twisting. A common mistake is improper alignment, which over time leads to loose-fitting doors.
