ᐅ Which Ikea Pax versions are available with sliding doors?
Created on: 26 Jan 2020 08:17
Agustin7
I am currently planning to furnish a new bedroom using the IKEA PAX wardrobe system and would like to use sliding doors to save space. My question is: What IKEA PAX options with sliding doors are currently available?
Specifically, I am interested in different sizes, door types, finishes, and possibly various interior organizers that are compatible with sliding doors. Are there options suitable for smaller rooms that offer certain modular features?
I would appreciate as detailed an overview as possible, including advice on the advantages and disadvantages of the different options.
Agustin7
27 Jan 2020 10:10
refinar schrieb:
Pay close attention to labeling each part before assembly and follow the instructions step by step.
Thanks, good advice! Could you also tell me if it’s possible to replace the doors on sliding doors yourself afterward, or is that very complicated? I’m considering starting with one model and then customizing it visually.
refinar
27 Jan 2020 10:35
Agustin7 schrieb:
Can you also say if it’s possible to replace the doors of the sliding doors yourself afterwards, or is that very complicated?
Yes, the Pax sliding doors can generally be replaced. You just need to carefully lift the doors out of the tracks and then click the new ones into place. It is important that the dimensions of the new doors match the frame exactly and that the running tracks remain compatible.
Some doors have different fittings, so it’s advisable to check this before purchasing. It’s not impossible, but it requires careful work and a bit of patience.
DUKUSU
27 Jan 2020 11:12
Great that you’re going into such detail here! I’m also a fan of PAX and sliding doors because they are a great solution for my room, which has limited space.
A small tip at the end: Have the sliding door frames measured at IKEA or try them out if possible. This makes planning easier and reduces the chance of mistakes!
