ᐅ Which Ikea PAX models offer the best quality?
Created on: 20 Sep 2017 18:37
suman
suman
20 Sep 2017 18:37
Hello everyone, I am currently looking into purchasing an Ikea PAX wardrobe system and am wondering which of the different PAX models offer the best quality based on your experience or knowledge. I am particularly interested in:
- Which versions or designs are recommended in terms of stability, material quality, and durability?
- Are there differences in the materials used or workmanship between newer and older models?
- How does the load-bearing capacity of the sliding doors compare to the standard hinged door options?
I am looking for a robust and long-lasting piece of furniture that will function well over time without major issues, and I would appreciate specific advice, comparisons, and practical experiences. Thank you in advance!
KINMIN4
20 Sep 2017 20:03
In my opinion, the PAX models with solid wood doors are of higher quality than the standard particleboard ones. The doors are more durable and feel more premium.
Also pay attention to the corner connectors and the floor structure. Models with metal frames usually offer greater stability.
RON57
20 Sep 2017 21:22
Hello suman,
Regarding your question: The PAX range from Ikea is quite diverse, and the quality does vary between the different versions. Generally, models with deeper carcasses and more robust support rails can carry heavier loads.
It is true that sliding doors are generally more susceptible to wear, especially if the running mechanism is used extensively or not maintained regularly. In contrast, standard hinged doors tend to be more durable, provided they are not overloaded.
In terms of materials, Ikea mainly uses particleboard with a melamine coating for PAX. The doors vary, ranging from plastic-coated to solid wood frames and veneers, which affects the price and durability.
I recommend paying close attention to the door design and interior layout before purchasing, as other manufacturers often offer better options here. Nevertheless, PAX is solid for the price.
Do you have specific uses in mind for which the wardrobe is intended? That would help to assess it better.
taotis53
21 Sep 2017 08:15
Several factors must be considered when evaluating the quality of the Ikea PAX models:
- Cabinet material: The vast majority are made from coated particleboard, which offers moderate durability. Solid wood options are rarely available in the standard range.
- Stability: Models with metal frames and reinforced connectors provide increased stability and therefore greater longevity.
- Door types: Both sliding doors and hinged door panels are available. Sliding doors put more strain on the tracks and roller systems, which means they require more frequent maintenance or replacement.
- Finishes: Matte lacquer and foil finishes differ significantly in scratch resistance.
There are no fundamentally “better” models, but rather configurations that are better suited depending on the specific requirements.
RON57 schrieb:
The PAX series from Ikea is quite diverse, and quality definitely varies between the different versions.
I agree. For maximum load-bearing capacity, the deeper cabinets with sturdy aluminum frames inside are recommended. For simple clothing storage without heavy loads, more affordable versions are sufficient.
Another point: assembly quality plays a crucial role. Even the best model shows weaknesses if it is assembled incorrectly.
DUKUSU
21 Sep 2017 11:08
I’m really glad that PAX is so versatile! 😄 I have several PAX wardrobes at home myself and actually find the quality quite good for the price. I especially like the models with glass sliding doors and aluminum frames—they look stylish and are sturdy.
What I’ve noticed is that if you handle the doors carefully and occasionally maintain the tracks with some silicone oil, the mechanisms last a long time.
So, if you want a durable wardrobe, I’d recommend investing in good door options and paying attention to sturdy corner joints in the carcass dimensions. That way, it’s enjoyable when everything holds up well and looks good!
suman
22 Sep 2017 09:39
taotis53 schrieb:
There are no fundamentally better "models," but rather different equipment options that are more suitable depending on the requirements.
That is indeed helpful to me, thank you for the assessment. My primary use will be in the bedroom as a wardrobe. Therefore, in addition to sufficient storage space, there should also be sturdy hanging options for clothes rails.
I am interested to know, based on your experience, how the different door types perform in daily use, especially sliding doors regarding noise levels and ease of handling.
Additionally, it would be interesting to know whether older PAX models are more stable in terms of quality or if Ikea has implemented improvements in recent years that should be considered.
