ᐅ Which Ikea Pax models have particularly sturdy shelves?
Created on: 27 Sep 2022 08:37
tarkin2
tarkin2
27 Sep 2022 08:37
Hello everyone, I am planning to get an Ikea Pax wardrobe system, and the stability of the shelves is particularly important to me. I am specifically interested in which Pax models have shelves that are considered especially strong and stable – not just in terms of material, but also construction.
I have read that there are different shelf thicknesses and variations within the Pax range, designed for various load capacities, but the catalog information is often too general. Are there any experiences or recommendations on which models or versions are truly suitable for heavy items due to their robust shelves?
It would also be helpful to know whether additional reinforcements are necessary or if certain shelves remain stable without any upgrades. Thanks in advance for detailed feedback!
TEBILO
27 Sep 2022 11:02
Hello tarkin2,
to thoroughly answer your question about the strongest shelves for Ikea Pax, we first need to differentiate the shelf types. Basically, Ikea offers two main types of Pax shelves: standard shelves made of particleboard with a melamine coating, and reinforced versions, which are sometimes made of solid wood or at least constructed with metal reinforcements.
The standard Pax shelves are about 16 mm (0.6 inches) thick and are suitable for light to medium loads, such as clothing or smaller items. If you want to store heavier objects, I strongly recommend using the metal drawer supports or additional metal reinforcements that Ikea offers as separate accessories for Pax. These metal supports significantly increase the load capacity, as the standard boards can sag over time.
Some users report that combining standard shelves with metal reinforcements offers the best balance, as the shelves remain flexible enough but become much more stable.
Another option is the closed shelves available in certain Pax models, which are stabilized by crossbars.
I’m curious about the exact weight you plan to place on each shelf? Because once you reach around 25-30 kg (55-66 lbs) per shelf, reinforcement is definitely recommended; otherwise, faster wear and sagging may occur.
Please provide a few more details here, so I can give you a more precise recommendation.
In summary:
- Standard Pax shelves: approx. 16 mm (0.6 inches), particleboard, load capacity up to about 15-20 kg (33-44 lbs)
- Metal-reinforced shelves (accessories): significantly higher load capacity
- Alternative models with sturdier constructions (e.g., shelves with crossbars)
Have you planned your cabinets for any specific heavy equipment or books?
Espen
27 Sep 2022 12:10
If you are looking for sturdy shelves for Ikea Pax, choose the shelves with metal reinforcement. The standard shelves are designed mainly for lighter items. Without metal reinforcement, heavy loads can quickly become problematic.
Danial
28 Sep 2022 09:46
TEBILO schrieb:
The standard Pax shelves are about 16 mm (0.6 inches) thick and suitable for light to medium loads, such as clothing or smaller items.
Although this is the official specification, I find it problematic to rely on general statements without more detailed load testing. Ikea does provide a maximum load capacity, but how realistic this is under everyday conditions remains questionable.
TEBILO schrieb:
As soon as you want to store heavier items, I strongly recommend the metal drawer supports or the additional metal reinforcements Ikea offers separately for Pax.
It should also be noted critically that while these additional parts do increase stability, they also make assembly more complex, and not everyone considers retrofitting them worthwhile—some customers have reported fit issues.
I would also suggest considering alternative shelving systems with stronger shelves outside of Ikea if you really need to handle heavy loads, since Pax is primarily designed as a modular solution focused on design and flexibility.
My critical question to everyone: Are there reliable long-term experiences with the metal reinforcements? Or are these more theoretical solutions without many users?
I look forward to fact-based experience reports.
CHENFAR
28 Sep 2022 14:09
In summary, the stability of Pax shelves largely depends on the type of shelf board used and any additional reinforcements.
The standard particleboard shelves are designed to support loads of about 15–20 kg (33–44 lbs). For heavier loads, it is definitely recommended to use the metal reinforcement, which Ikea specifically offers for the Pax series and which is well compatible.
There are also special additional cross braces and shelf supports that further increase the load capacity of the shelves. These components are no more complicated to install than the standard fixed parts and have been tested in various ways.
I have several wardrobes with Pax and metal reinforcement in use, some for over three years, without any bending or loss of stability. The reinforcements have the advantage of distributing the load over several points.
Recommendations:
- Always use metal reinforcement for loads greater than 20 kg (44 lbs) per shelf.
- Pay attention to cross braces that provide additional stability.
- Consider weight distribution and store heavy items as low as possible.
This is practical experience based on several real-life applications.
tarkin2
29 Sep 2022 07:28
TEBILO schrieb:
I’m curious about the exact weight you plan to place on each shelf? Because once you reach about 25-30 kg (55-66 lbs) per shelf, reinforcement is definitely recommended to prevent faster wear.
Good question, I actually plan to store about 30-35 kg (66-77 lbs) per shelf, including books and some heavier technical components. That is definitely more than just light clothing.
Danial schrieb:
My critical question for everyone: Are there any reliable long-term experiences with metal reinforcements? Or are these more theoretical solutions without many users?
I’m interested in such feedback as well, since it would be very frustrating if these reinforcement options turn out to be only semi-stable in practice.
CHENFAR schrieb:
I have several cabinets with Pax and metal reinforcement in use, some for over 3 years, without any sagging or loss of stability.
That sounds promising! If the reinforcements have truly proven effective, I will likely focus on that solution.
I would still like to know if there are differences in the material quality of the shelves among the Pax models, or if the main difference really lies only in the accessories? For example, does the depth or width of a cabinet also play a decisive role in stability?
Thanks for the detailed information so far!
