ᐅ Which Ikea PAX models are suitable for use as wardrobes?
Created on: 2 May 2024 18:47
Bargu
Bargu
2 May 2024 18:47
I’m planning to get a new wardrobe and have been researching the Ikea PAX system in detail. Since there are many different versions and models, my specific question is: which PAX models work best as wardrobes? I’m especially interested in aspects such as stability, storage capacity, flexibility in interior layout, and, of course, value for money.
I would particularly like to know which widths, heights, and possibly door options you would recommend, as well as which combinations of the frame and interior elements (drawers, clothes rails, shelves, etc.) are most practical.
Maybe you also have tips on what to consider if you want to fit the wardrobe into a niche or along a limited wall space.
I look forward to your experiences and recommendations!
Jukin
2 May 2024 19:21
Hello Bargu,
I understand that choosing within the Ikea PAX system can be quite overwhelming due to the variety. Generally, the most popular wardrobes are 75 cm (30 inches) wide, as they fit well in standard rooms while still offering enough storage space.
Regarding heights: there are options of 201 cm (79 inches) and 236 cm (93 inches). The taller version is great if you have plenty of space and often need extra storage – but be sure to consider the ceiling height so it doesn’t feel too imposing.
A tip for flexibility: inside, you can customize exactly to your needs using drawers, shelves, and hanging rails. For clothes that need to hang, at least one hanging rail is recommended; for folded clothes, shelves work well. Drawers are perfect for underwear or smaller items.
Doors come in many styles – from classic to glass fronts. If the room is small, I suggest leaving it open so it doesn’t feel cramped, or choosing sliding doors if space in front is limited.
If you want to learn more about specific models, we can go into further detail.
Nabla64
3 May 2024 08:36
Hello Bargu,
I would like to answer your question in a more structured way. The PAX system basically offers different standard modules with widths of 50, 75, and 100 cm (20, 30, and 40 inches).
- For a wardrobe that should accommodate both hanging and folded clothes, the 75 cm (30 inches) wide modules are the most versatile.
- The height of 236 cm (93 inches) is especially recommended for rooms with high ceilings, as it allows you to use the entire space efficiently without needing additional top shelves.
- Interior layout: I suggest using a mix of at least two hanging rods (one upper, one lower), shelves, and at least two drawers for smaller clothing items.
- Doors: Classic hinged doors are ergonomic and easy to operate, while sliding doors save space in front of the wardrobe but require more effort for assembly and maintenance.
- For alcoves, it is essential to pay close attention to exact measurements since PAX elements are sold in fixed standard sizes. Combining 50 cm (20 inches) and 75 cm (30 inches) modules can be helpful to avoid gaps.
Summary:
- PAX 75 x 236 cm (30 x 93 inches) modules with a mixed interior layout usually fit best.
- Choose the interior layout strictly based on your personal clothing profile.
- Door type depends on room size and how the space is used.
If you provide more precise measurements and specify your clothing categories, I am happy to help with the optimal configuration.
Domau0
4 May 2024 11:52
In addition to the previous very good explanations, I would like to highlight some technical details and practical experiences that can help you choose the right PAX model as a wardrobe:
1. Load Capacity: The PAX frames are sturdy enough for everyday clothing but need to be well secured when storing heavier items (e.g., many shoes, heavy jackets). Wall anchoring is strongly recommended to prevent tipping hazards.
2. Interior:
- For shirts, suits, and dresses, at least one continuous hanging rod about 120 cm (47 inches) wide is advisable to avoid overcrowding the clothes.
- Shelves can be adjusted in 1.5 cm (0.6 inch) increments, but you should pay attention to the load capacity (maximum 15 kg (33 lbs) per shelf).
- Drawers come in different heights; combination sets with shallow drawers for underwear and deeper ones for sweaters work best.
3. Doors:
- Sliding doors are beneficial in tight spaces but offer lower storage capacity due to reduced simultaneous access to different wardrobe sections.
- Hinged doors allow full access to the interior but require more clearance space.
4. Practical Tip for Assembly:
- Assembly takes several hours depending on the model and requires at least two people.
- Accessories such as LED interior lighting can improve visibility but need to be purchased separately.
5. Special Models with integrated mirrors or glass sliding doors can be very attractive but significantly increase the price.
6. Purchase Advice Based on Room Size:
- For room heights above 240 cm (8 feet), the 236 cm (7 feet 9 inches) version is worthwhile.
- For smaller rooms, 201 cm (6 feet 7 inches) modules are better suited, as you might create additional storage space on shelves above the wardrobe.
Could you provide more details about the room size, the quantity, and type of your clothes? Then I can also offer recommendations on which specific component combinations would be suitable for you.
andre3
5 May 2024 09:03
In summary, the question of which Ikea PAX models are best suited as wardrobes can be briefly and clearly addressed based on selected criteria.
- Stability: PAX frames in the standard widths of 75 and 100 cm (30 and 39 inches) are equally load-bearing; the 50 cm (20 inches) models are better suited as additions.
- Storage space: 75 cm (30 inches) wide modules offer the best balance between width and clarity, are more flexible than 100 cm (39 inches) wide units, and are easier to configure in alcoves.
- Interior fittings: A combination of hanging rails and shelves is ideal. Drawers, e.g. 50 cm (20 inches) wide, complement the layout but are optional.
- Doors: Hinged doors are suitable for rooms with sufficient clearance, sliding doors for limited space. Glass fronts are appropriate for representative rooms.
- Price-performance ratio: Standard modules with a height of 201 cm (79 inches) are usually more affordable; if there is more space, upgrading to 236 cm (93 inches) height is worthwhile.
Final note: The choice depends largely on individual space conditions and personal usage scenarios. For a precise recommendation, more details about the room situation and intended use would be helpful.
