ᐅ Which Ikea Pax models are particularly quick to assemble?
Created on: 27 Sep 2024 20:37
franspau
franspau
27 Sep 2024 20:37
After looking into the topic of Ikea Pax for a while, I have a specific question that might gather some shared experiences here: "Which Ikea Pax models are the quickest to assemble?"
I’m less interested in the design or the doors, and more focused on which frame or interior components can be put together most quickly, especially when working alone.
Perhaps some of you have already tried specific variants or combinations where the assembly was noticeably faster than with others. I’m thinking about build times, a manageable number of parts, ease of following the assembly instructions, and the tools required.
Any tips on common pitfalls or special advice on how to make the assembly more efficient would also be great.
Thanks in advance for your insights and experiences!
likuken
27 Sep 2024 21:15
Provocative statement: With the Ikea Pax system, you can hardly ever be really fast – it’s one of those products where the total time is three to four times the actual assembly time because you have to make so many decisions and swap parts for customization.
But if you ask me, the simpler versions with plain sliding doors and minimal interior fittings go together the fastest. Why? Fewer parts, fewer screws, and less fiddling.
For real speed with Pax, I’d only suggest skipping all additional modules and sticking to the basic frames – and, if possible, buying pre-assembled doors. But let’s be honest: anyone who buys Pax wants that flexibility, so it pretty much always takes time.
Does anyone have different experiences to share?
KAULIS
27 Sep 2024 22:09
likuken schrieb:
this is a typical product where the assembly time is three to four times longer than the pure setup time
Objectively, this is a realistic assessment.
From my experience, Pax models with standard dimensions, such as the 100cm (40 inches) width without internal dividers, are the fastest to assemble.
Important:
- Frames measuring 50x236cm (20x93 inches) or 100x236cm (40x93 inches) are somewhat quicker because fewer screws are needed and the parts are easier to manage.
- The more drawers, shelves, and internal organizers you choose, the more complex and time-consuming the assembly becomes.
- Doors: Sliding doors significantly delay assembly since the tracks need to be precisely adjusted. Hinged doors with simple fronts are generally faster to install.
A tip for anyone who wants to finish quickly: Plan the frame parts completely in advance and, if possible, buy doors pre-assembled.
To give you an idea: An experienced assembler can complete the basic Pax frame in about 30-40 minutes, internal organization takes another 30-45 minutes. Adding doors takes an additional 20-30 minutes, depending on the type.
In summary: For fast assembly, reduce to few parts and doors, minimal internal divisions, and careful preparation.
Palenar
28 Sep 2024 10:53
KAULIS schrieb:
Sliding doors significantly delay the assembly because the tracks need to be precisely adjusted.
I can only confirm that, especially with sliding doors the time factor lies in the fine adjustment, which often requires even more effort on uneven floors or walls.
To provide more detailed answers to the original question, I have personal experience with several Pax combinations.
- The 100x236 cm (39x93 inches) model with a standard frame and simpler interior components is very quick to assemble, as KAULIS says.
- The smaller 50x201 cm (20x79 inches) frames usually take about an hour to assemble, ideal if you have limited time or are working alone.
- As for the doors: hinged doors without soft-close are much easier to install than those with built-in damping mechanisms.
- Interior fittings: I recommend installing only the absolutely necessary shelves and clothes rails. Drawers and organizers take significantly longer.
Preparation is also important: sort screws clearly, check all parts, and have the assembly instructions printed out or open on a tablet nearby.
You should also have two types of screwdrivers ready, Phillips and possibly an Allen key, in case you have longer models with special fittings.
Finally, a small tip: if someone like franspau really focuses on quick assembly, frame and interior element combinations without doors are, in my view, the most efficient – doors can always be added later when there is more time.
