ᐅ Which Ikea Pax interior organizers are the most flexible?
Created on: 2 Dec 2021 19:27
nedifar
nedifar
2 Dec 2021 19:27
I am planning to get a new Ikea PAX wardrobe and want to keep the interior organization as flexible as possible. Therefore, I am interested in which of the available PAX interior systems you consider the most adaptable when it comes to different storage needs and changing requirements.
I’m looking for details such as whether certain shelves, drawers, or hanging systems are particularly easy to adjust or rearrange without requiring complex modifications or purchasing additional parts. It would also be useful to know how well these systems can be expanded or repurposed later—for example, if you want to convert a wardrobe primarily for clothing into more storage for accessories.
Does anyone have experience or recommendations that could help me design the interior to be as flexible and future-proof as possible?
Looking forward to your opinions and tips!
Danial
2 Dec 2021 22:11
nedifar schrieb:
I’m interested in details such as whether certain shelves, drawers, or hanging systems are especially easy to adjust or reorganize without requiring major remodeling or the purchase of new parts.
That’s an important point. In my experience, the PAX internal organization is modular but only somewhat flexible. Most drawer systems or shelves have mounting holes at fixed intervals, which does allow for some reorganization but within certain limits.
Also, some shelves are a bit harder to move because the brackets can’t be released without tools or need to be positioned very precisely.
Interestingly, the Utrusta drawers with side-mounting profiles allow for relatively faster rearrangement since you often only need to release clips. Still, the system is not designed for constant changes.
For maximum flexibility, I would recommend relying less on fixed attachments and more on combinations of adjustable baskets, inserts, and hanging rails that can be relocated more easily.
meGreg
3 Dec 2021 07:42
Danial schrieb:
For maximum flexibility, I would recommend relying less on fixed solutions and more on combinations of adjustable baskets, inserts, and clothes rails that can be easily rearranged.
I agree, though with a slight smile 😊. The Ikea Interna systems are really like the Lego bricks of furniture – you can combine and swap a lot, but sometimes that’s the catch: there are many parts to assemble, leading to almost endless possibilities. For me, that’s a plus because I like rearranging and reorganizing all the time.
In my opinion, it gets even more flexible when you include other Ikea basket systems or storage boxes inside the drawers, which you simply place into suitable compartments without necessarily fixing them permanently. This might sacrifice a bit of stability, but personally, I find the flexible access incredibly practical.
If you want less tinkering, you can of course also consider the proven drawers with soft-close and well-thought-out interior division. But then it’s no longer quite as flexible.
LOJOPAR
3 Dec 2021 10:18
I would like to provide a brief overview to help you organize the PAX wardrobe as flexibly as possible according to your needs:
- Shelves: These are classic and provide stability. They are relatively easy to reposition using simple metal brackets, which are hooked in at 32mm (1.25 inches) intervals. However, they are fixed and not suitable for variable compartment sizes.
- Drawer inserts (Utrusta system): Very practical because they can be combined with both fixed compartments and pull-out boxes. They are relatively easy to install and remove.
- Clothes rails: Ideal if you mainly want to store clothes. The length can be adjusted, and multiple levels increase capacity. The rails are very flexible since they can be quickly hooked in and removed.
- Baskets and wire mesh: Probably the most flexible elements, as you can freely combine different sizes and easily remove them for quick access.
Tip: A combination of at least two of these elements ensures maximum flexibility. Using shelves alone too often can become inconvenient if you want to reorganize frequently.
Summary: Those who want to frequently rearrange should opt for modular drawers and baskets, with a few clothes rails in between to cover a variety of needs.
fikeo
4 Dec 2021 00:03
I would like to add an aspect that is often overlooked but can be crucial for flexibility: the load capacity of shelves and drawers. Anyone planning to store a variety of items – from heavy shoes to delicate clothing – needs systems that can handle these without losing stability.
A tip from personal experience is to pay attention to the weight limits of the shelves. Standard slats are not always the strongest and can sag quickly if overloaded. For example, some manufacturers offer reinforced shelves, which may be less “flexible” in terms of quick rearranging but are generally more durable.
In general, when planning the interior layout, it helps to find a balance between flexibility (meaning easy to modify) and robustness (so everything is stored securely). A good solution is often to install sturdier shelves at the bottom and use more flexible elements like baskets and drawers at the top.
This actually increases your everyday flexibility, as you’re less likely to have to replace parts that have broken due to overloading.
O
olivernu
4 Dec 2021 09:35
LOJOPAR schrieb:
As a tip: A combination of at least two of these elements ensures maximum flexibility.
I would like to agree with this and add that when planning, it’s important to also consider future usage.
Flexibility doesn’t just mean being able to rearrange things, but also being able to adapt the interior organization to new requirements in a practical way without having to buy everything new.
Therefore, you should:
- choose common, lightweight systems that are compatible in various versions (e.g., Utrusta, Komplement)
- if possible, pay attention to universal dimensions so that other Ikea systems fit as well (e.g., Samla boxes alongside drawers)
- use mounts that don’t require screwing, but instead rely on clips and rails
In summary: As a practical tip, anyone who often changes their organization should prefer a modular, straightforward setup and avoid rigid, highly customized boxes.
