ᐅ Which Ikea Pax drawers are especially durable for frequent use?
Created on: 1 Oct 2017 14:37
O
Onsiron
O
Onsiron
1 Oct 2017 14:37
Hello everyone, I am currently planning to equip my bedroom with an Ikea Pax wardrobe, and I am especially focusing on the drawers, as I will use them very frequently – for clothing, but also for heavy items like shoes and possibly small boxes with technical accessories. My question is: Which Ikea Pax drawers are particularly stable and durable with frequent use, without the runners or the drawer body wearing out quickly? I have done some research and come across different widths and configurations, but especially the high-quality versions seem to vary quite a bit in price. Are there specific recommendations among the drawer options in the Pax system for users who open and close drawers often and a lot? I would also appreciate any experiences regarding which materials or models have proven reliable, so I don’t end up buying unnecessary weak points. Thank you very much in advance for your advice!
bijo54
1 Oct 2017 15:09
I would recommend drawers with full extension and metal sides, as they are more durable than plastic versions. Especially for wider widths, many opt for drawers with metal frames, which continue to operate smoothly even after extended use. There isn’t much more to consider.
farkin
2 Oct 2017 09:42
Hello Onsiron, I’m happy to take some time to explain the main points that can help you choose the sturdy Pax drawers. First of all, Ikea offers two main types of drawers for the Pax system:
- Drawers with one side panel made of wood-based material and a metal frame around the front (better for stability and load distribution)
- Standard drawers made entirely of wood-based material, which are somewhat cheaper
The durability also depends on the drawer slides: the better models come with full extension and metal runners, which can handle pull-out weights of up to 25 kg (55 lbs) or more.
You should also pay attention to the drawer width: the wider it is, the more the mechanism has to support, and that’s where metal sides are definitely recommended.
So, if you store heavy items or use the drawers frequently, I recommend:
- Drawers with a metal frame or fully metal runners
- Looking for full extension slides to ensure smooth operation without warping
- Possibly adding fixed intermediate shelves or reinforcements if you plan to carry very heavy loads
In summary: the somewhat more expensive metal-framed drawers are definitely safer for your requirements in the long run. This is also supported by experiences shared in various forums and reviews.
I hope this helps!
Josan
2 Oct 2017 11:17
Hello Onsiron,
I would like to add a few points because the stability of the Ikea Pax drawers depends on several factors, and this topic is often underestimated.
bijo54 schrieb:
I would recommend drawers with full extension and metal sides, as they are more stable than the plastic versions.
That is true, especially the full extension slides are important, as they ensure an even load distribution and prevent the drawer from tilting out of the track under heavy use.
A few years ago, I chose the larger drawers equipped with metal frames and higher-quality runners myself. Especially with frequent opening, these guarantee long-lasting use without needing adjustments.
If you plan to load the drawers very heavily, I recommend considering not just the mechanism but also the mounting hardware—meaning whether the drawers are securely fixed inside the cabinet. Sometimes it’s worth adding individual reinforcements or using extra shelves to achieve better load distribution.
I hope these tips help you, because especially with frequent and intensive use, it’s always worthwhile to invest a bit more in sturdier drawers.
