ᐅ Which Ikea Pax doors are the easiest to clean?
Created on: 24 Dec 2024 08:37
Rulennard
Rulennard
24 Dec 2024 08:37
Hello everyone, I am planning to get an Ikea Pax wardrobe soon and am particularly focused on the choice of doors. Since I value ease of maintenance highly, I am especially interested in doors that are quick and simple to clean. Can you share from your own experience which Pax doors are easiest to keep clean in everyday use? I am thinking about materials, surface finishes, and how well they handle stains or fingerprints. It would be great if you could also provide cleaning tips or mention any differences to consider depending on the door type (sliding vs. hinged doors, etc.). Thanks in advance!
Davidleo
24 Dec 2024 08:59
Hey Rulennard! Great question, I love it when practical things are questioned like this! 🙂 From my own experience, I can tell you that the white high-gloss Pax doors are absolutely excellent when it comes to cleaning. The surface is quite smooth, so dust and stains don’t settle easily. I usually just use a microfiber cloth and some mild dish soap, and it cleans up really quickly – even fingerprints! Sliding and hinged doors don’t make much difference to me in this regard. The only important thing is not to use abrasive cleaners on the doors, or the gloss will get scratched. I really appreciate how easy they are to maintain, so thumbs up! Good luck with your project, it will turn out great 😊
Domau0
24 Dec 2024 10:12
Hello Rulennard, your question touches on a point that is often underestimated. In my opinion, the ease of cleaning Ikea Pax doors mainly depends on two factors: material and finish. Specifically, do you prefer painted, foil-covered, or solid wood surfaces? The Ikea Pax range offers doors with frame-style designs featuring different insets, painted doors in matte or glossy finishes, as well as foil-covered surfaces.
From a technical standpoint, painted high-gloss surfaces are the easiest to clean because they form a sealed layer that repels water and cleaning products. For these, a slightly damp, lint-free cloth and possibly a neutral cleaner are sufficient. Matte paint is more delicate and should be treated gently.
Foil-covered doors tend to absorb stains more quickly and are more prone to scratches. For hinged doors, also consider the hardware: sliding versus hinged doors – the latter can require more cleaning effort due to hinges and edges. Sliding doors have fewer edges, but the frame can collect dust.
What type of room are you currently using, and what types of dirt or stains do you expect mostly? This could further influence your choice.
neoren
24 Dec 2024 10:28
I recommend the high-gloss lacquer doors. They have a smooth surface, do not absorb stains, and can be quickly cleaned with a damp cloth.
Rulennard
25 Dec 2024 09:03
Thanks in advance for the helpful information! @Domau0, your distinction between materials and finishes is very relevant. I currently have a relatively small bedroom without a window right next to the closet, so ventilating might only cause moderate humidity. The doors should mainly be durable against dust, fingerprints, or occasionally placing clean clothes on them. I am currently leaning towards painted doors, preferably matte, as they fit better visually. However, your comment about the sensitivity of matte paint is making me a bit concerned – could you briefly explain the best way to clean them or what to avoid? If there are general care tips for matte paint, that would be great.
koduga
25 Dec 2024 09:39
Hello Rulennard, I completely understand that you’re unsure about your choice! I personally am quite sensitive to small scratches and fingerprints. At my home, I have matte lacquered Pax doors, and I always clean them very gently with a microfiber cloth, using no cleaning agents or just a little water.
Domau0 schrieb:
It becomes tricky with matte lacquer; it is more sensitive and should be treated carefully.
Exactly! I once tried to clean more aggressively to remove dirt better, but that unfortunately caused slight clouding on the surface. Since then, I only use lukewarm water and gently wipe.
So if you want matte, it’s better to clean frequently and gently rather than rarely and with heavy scrubbing. That way, your doors will stay nice for longer. Maybe testing on a small area first would be advisable. Not sure if this helps?
