I am currently planning to purchase a new Pax wardrobe and need to decide which doors to choose. It is especially important to me that the doors are sturdy and durable, particularly with frequent use, while also being resistant to scratches or dents.
I would like to know: Which Ikea Pax doors are particularly durable? I am referring to the materials, workmanship, and general wear and tear in a typical living environment – not just appearances, but also long-term functional reliability.
Has anyone had experience with the different options, such as solid wood or glass fronts, and can assess which doors are more durable? Information about fittings and hinges that might affect durability would also be helpful.
Thanks in advance!
Thanks in advance!
Here is a brief overview of choosing particularly durable Pax doors:
- Solid core doors: made from compressed wood fiberboard, relatively thick and more robust than foil-wrapped or painted doors.
- Painted doors: feature a protective, more scratch-resistant surface compared to foil-coated versions.
- Glass fronts: difficult to dent but fragile when impacted.
Common installation mistakes, such as incorrectly mounted hinges, can significantly reduce durability. Always make sure to hang the doors using the appropriate fittings according to the IKEA assembly instructions and regularly tighten them.
For daily use, the solid core option is the most recommended. You can also consider how often the doors will be used and opened to select the appropriate thickness.
If you need more technical details about hinges or installation, feel free to ask.
Nathanaelk schrieb:
Glass fronts, usually with inserts made of tempered safety glass, look modern but can break or crack more easily when impacted—especially if you have small children or pets.This is important to emphasize. While glass is scratch-resistant, it is not the best choice for everyday durability, particularly in households with a lot of activity.
Jensson schrieb:
For daily use, the solid-core option is the most recommended.I fully agree. The combination of material thickness and surface makes solid-core doors the most durable choice. Doors with laminate finishes are more affordable but less resistant to mechanical stress.
Those prioritizing long-term durability should especially pay attention to the paint finish—whether high-gloss or matte. These options are more resistant to moisture and scratches.
flo-Theres2 Apr 2024 12:36In short and concise terms: For maximum durability, I recommend solid core doors with a matte or satin finish. These provide a good balance of impact resistance and scratch protection.
Glass fronts are visually appealing but less practical for everyday use if longevity is the priority.
Hinges should also be checked regularly and adjusted as needed to prevent damage caused by misaligned opening.
My advice: If you want to protect the doors further, transparent protective films on the painted surface can be a worthwhile investment.
